Chain fence eating turbo
Will the JE 98mm piston rings work with Max Moritz pistons?
As the title says, I see Pelican offers 98mm JE piston rings for cheaper than I paid for TotalSeal conventional rings for my FLATTOP Max Moritz pistons.
Will these work? I assume yes, but wanted to confirm.
PN: JE-612U6-3858
Wanted to order soon, or I would have measured everything to confirm.
TIA
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-06-2017, 08:26 AM
I think you will have to machine the pistons unless they already use the same size rings,
Max Moritz 98mm pistons which I had in the past used a ring pack which is 1.2 x 1.2 x 3.0mm and it is difficult to find rings to suit.
The Mahle Motorsport version of this piston uses a 1.0 x 1. x 2.0 mm ring pack.
I think JE use NPR Rings which are good.
Old 01-06-2017, 08:49 AM
Bummer.
JE shows 1.5 X 1.5 X 3.0
Old 01-06-2017, 08:55 AM
kuehl's Avatar
What compression ratio?
Any Boost?
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 01-06-2017, 08:58 AM
Any Boost?
7.5:1, yes, 1.4 bar or higher of boost
Old 01-06-2017, 09:00 AM
kuehl's Avatar
I don't have flat tops, but I was cracking rings on my 100mm with rings that came with my JE 9.5:1,
single plug hemi head location and 8 psi boost don't help, lol.
I had Total Seal figure out what I needed, they were worth every penny and the tech support was great.
Kuehl
Old 01-06-2017, 09:12 AM
Yeah, I'll have to go TotalSeal again, then.
Old 01-06-2017, 09:41 AM
I would measure the piston just to sure of the ring sizes.
Old 01-06-2017, 11:59 AM
I would, but my engine is together right now.
Old 01-06-2017, 02:26 PM
I have a most complete set low mileage Mahle, I think there was one broken in the set.
I had to buy a full set of totalseal for the one broken OE
Bruce
Old 01-07-2017, 10:40 AM
Bruce
If it were a Ford on Chevy, you could have bought one.
Porsche tax!
Old 01-07-2017, 11:42 AM
Nux Nux is offline
Nux's Avatar
Reviving an old thread since I'm currently doing a top-end rebuild on my 3.2 Max Moritz conversion.
I'm at the least page of the internet, and found nothing yet?!
Did you guys find the piston rings anywhere or do I order from Total Seal?
Thanks!
Old 02-11-2018, 11:03 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
Nux,
I would give EBS Racing a call. They will be able to give you the scoop on the rings for your pistons.
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 02-12-2018, 11:26 AM
Originally Posted by KTL View Post
Nux,
Yep, what I did before.
I only started the thread because I saw the JE rings are much cheaper than my custom TotalSeal's I got from EBS.
Old 02-12-2018, 11:35 AM
Nux Nux is offline
Nux's Avatar
Nux,
First thing in the morning then - thanks!
Old 02-12-2018, 11:36 AM
