-   -   Largest duration/highest lift regrind from Carrera 3.2 cams? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/942123-largest-duration-highest-lift-regrind-carrera-3-2-cams.html)
Tippy 01-11-2017 09:49 AM
As the title says, how big can I go?
I have 993SS's (brand new WebCam) sitting on my shelf, but rather have GT2 Evo's or there about.
Also, the LSA is a little too tight for me. Rather stay 113.
Wondering how much "cam" I can get out of regrinding my 3.2's??
TIA
KTL 01-11-2017 10:41 AM
drcamshafts.com used to have a bunch of footnotes/comments in one column of the cam listings on the website. those notes identified what each cam's details are. But I see he's removed that. Nonetheless John/camgrinder would have that information on the top of his head to share with you.
Tippy 01-11-2017 11:20 AM
Yeah, he changed it awhile back. I want to say 964 was the biggest?
KTL 01-11-2017 11:49 AM
I had him regrind my original '87 3.2 cams into the DC-20 "Super C2" profile. He doesn't list that cam anymore. So i'll guess the DC-19 is the most aggressive he can regrind to? DC-19 is a bit more aggressive than 964.
With my cam, I recall it had a recommended 2.2-2.4mm lift/timing spec at TDC overlap which I posted here on the forums. That timing spec was pretty tight on piston-to-valve clearance so I had to back it down to 1.8mm in order to get ample clearance. I didn't want to pull the pistons out of the cylinders (I was just doing the valve guides at the time) and have them machined for valve reliefs. So I compromised on the cam timing.
Tippy 01-11-2017 12:44 PM
Aren't the DC20's 993SS's?
KTL 01-11-2017 01:15 PM
I don't believe so. His 993SS has one degree more of lobe separation than the Carrera/SC cam and I don't believe you can modify lobe separation w/out making a new cam? I also don't think he simply renamed it because the timing lift spec. is different than the card I got with my DC-20 cams.
But who knows, maybe he just decided to tweak it a bit with an additional degree of lobe separation, and eliminate the DC-20 profile to be replaced by DC-993SS. And also change the recommended lift spec to make it work with stock pistons? Otherwise the question would frequently be, what's the difference between the DC-20 and DC-993SS
I recall hearing in the past that the Web 20/21 was said to be their version of the 993SS. But I see Web's website (is that an oxymoron? ;) ) shows both a 20/21 profile and a 993SS cam. When you click on the actual links for the cams, there is a slight difference between those two profiles in terms of lift specs, durations, lobe centers and timing settings
Web Cam Inc. - Performance and Racing Camshafts / Porsche 911 SOHC 12v Timing Card for 20/21 profile
Web Cam Inc. - Performance and Racing Camshafts / Porsche 911 SOHC 12v Timing Card for 993SS mechanical rocker profile
cgarr 01-11-2017 05:01 PM
I have DRC's spec sheets for all his cams printed from the site if you want me to text or email them to you?
