-   -   3.2 Cylinder Too Wide, what would you do? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/942879-3-2-cylinder-too-wide-what-would-you-do.html)
DRACO A5OG 01-18-2017 02:51 PM
Tim at Ollie's just notified me: my cylinders are out of spec at 3/1000th, max oem spec is 1.5/1000th.
With Limited Budget, what would you do?
My thought is to widen to 98MM 3.4L with new 9.5:1 Pistons ( keep it single plug )
TIA,
Jim
VFR750 01-18-2017 04:22 PM
Limited budget and Porsche engines are not compatible.
You can stay at 95mm with a replate of the bores or go larger for a little bit more cash with 3.2 based cylinders.
Ebs racing could set you up with 98mm replated cylinders and JE pistion for about $2k. not sure there are any cheaper alternatives.
DRACO A5OG 01-18-2017 06:17 PM
Agreed :D
Yeah, the larger piston set just bring me over $1000 over budget, so not bad. I was expecting Cylinder work but bore and honing will certainly be done.
Thanks for chiming in.
Lyle O 01-18-2017 06:36 PM
I went with EBS on the bore to 3.4, and then 9.8:1 Max Moritz Mahle pistons. Still single plug (though I am in Michigan and we have 93 octane gas). Beautiful outcome. You save a lot by not having to buy new cylinders, and MM pistons are, if I recall, comparable in price to JE. Also, talk to Steve Wong about the set up; he has great input on this.
Remember, you hopefully only have the thing torn down one in a great while; take advantage of the opportunity! Best of luck...
Tippy 01-18-2017 06:52 PM
Henry from Supertec just posted he has tons of heads lying around. Maybe he has a cylinder?
Rawknees'Turbo 01-18-2017 06:59 PM
Originally Posted by DRACO A5OG (Post 9437847)
. . . what would you do?
Jim
I would put 3.3L Turbo pistons and cylinders on there and then boost that bisch! :D
KTL 01-19-2017 09:23 AM
Part it out and buy a good used C5 Corvette Z06?
Henry Schmidt 01-19-2017 10:23 AM
911 Vintage Parts
Ken 760-731-4911
info@911vintageparts.com
http://forums.pelicanparts.com/uploa...1484850056.jpg
http://forums.pelicanparts.com/uploa...1484850079.jpg
http://forums.pelicanparts.com/uploa...1484850114.jpg
http://forums.pelicanparts.com/uploa...1484850181.jpg
Tippy 01-19-2017 11:07 AM
Voila!
Walt Fricke 01-21-2017 10:13 AM
Old 911 engine parts never die, they just end up on Henry's shelves!
JFairman 01-21-2017 05:55 PM
Impressive collection of stuff :)
Sboxin 01-22-2017 03:43 AM
TIA,
Jim
Just curious - - what did Ollie's recommend for your cylinders?
We did a 3.6L 964 rebuild and sent the cylinders to EBS - - went to 3.8L . . .
Regards,
DRACO A5OG 01-22-2017 08:05 AM
^^^ I have not spoken to them yet. Will try them again Monday.
Wow a SC 3.8L? Wow Wow.
gtc 01-24-2017 10:45 AM
I'm curious if you could find a good used set for less than it would cost to replate and hone back to 95mm spec.
WERK I 01-24-2017 12:41 PM
Here's what I was quoted from U.S. Chrome last February, which most everyone ships their cylinders to.
$199 each for a basic replate
$230 each if skim cut the bore to get to good base metal and shape
$262 each if any welding is needed
You didn't mention whether your pistons are in spec. In any case, pistons must be sent in with cylinders to insure proper fitting tolerances.
