-   -   Alusil Cylinder Pitting (http://forums.pelicanparts.com/911-engine-rebuilding-forum/943369-alusil-cylinder-pitting.html)
jbahrami 01-22-2017 10:21 PM
Hi there,
I am cleaning my cylinders in preparation for a rebuild. I noticed today that one of the cylinders has some small pitting. Could anyone who has experience with this type of problem comment about how the cylinder looks, and if they feel the cylinder could be reused?
Thank you,
Jeff
jbahrami 01-22-2017 10:26 PM
http://forums.pelicanparts.com/uploa...1485152752.jpg
Sigurd 01-23-2017 12:18 AM
I will be very surprised if anyone that knows more about this than I do, tells you it can be used as is.
Tippy 01-23-2017 06:16 AM
If it were below the area where the rings contact, it'd probably be fine. But it's not unfortunately.
Eagledriver 01-23-2017 09:14 AM
Looks like a manufacturing defect. Some porosity in the original casting. You'll have to be the judge, but I suspect it's been there since the beginning. It's way down inside the cylinder so it will have a minimal effect on compression. I might try to find a single replacement but, if your wear is minimal you'll have a hard time finding a better replacement. I'd be tempted to reuse it.
-Andy
