-   -   Name those rod bolts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/943482-name-those-rod-bolts.html)
pampadori 01-24-2017 04:35 AM
Working on the slowest engine rebuild ever done, removed the rods and found these bolts. They don't have any markings that I can see on them. What brand might they be?
Also, they are 2.7 rods, right? Big end is almost 24mm thick.http://forums.pelicanparts.com/uploa...1485261466.jpg
pampadori 01-25-2017 07:05 PM
I'll ask in different words what I'm really trying to learn. Do you think these are 1 time use or can I reuse these guys?
Mick_D 01-25-2017 07:29 PM
never reuse anything you're unsure of.
Jeff Alton 01-25-2017 08:56 PM
they look like ARP. If so they should have a marking on the head.
pampadori 01-26-2017 07:29 AM
no markings on them anywhere. I have emailed some pics to Raceware to see if they recognize their children or not. THey do appear to be treated or coated or something. They are darker than most of the other hardware. They "feel" very premium for whatever that is worth.
Mick_D 01-26-2017 07:47 AM
If you really want to name them, you could use the names of the Dwarves from The Hobbit.
Let me see if I remember them:
Ori Nori Dori Oin Gloin Balin Dwalin Bifur Bofur Bombur Fili Kili - that's 12- and Thorin Oakenshield, in case you have a spare.
Though why you would want to name your rod bolts after dwarves is beyond me.....
'76 911S 3.0 01-26-2017 09:42 AM
The nuts certainly don't look like an OE part...
kwikt 911 01-26-2017 04:41 PM
Looks like rod nuts from a 968
Jeff Alton 01-27-2017 06:17 AM
The 993 nuts look the same. After looking again, not ARP as I don't see a dimple in the bolt head to center a stretch gauge.
Cheers
stownsen914 01-27-2017 11:17 AM
Raceware? Here's a link to the Raceware ones that Pelican sells.
RACEWARE Connecting Rod Bolt Set PELRTE4004 - Raceware - PEL-RTE-4004 | Pelican Parts
