-   -   77 2.7 issue (http://forums.pelicanparts.com/911-engine-rebuilding-forum/943652-77-2-7-issue.html)
IMR-Merlin 01-25-2017 10:50 AM
77 2.7 issue
Hi guys, I have a sick 77 2.7 at my place.
Customer/friend brought it in to me, hasn't run in 11 years.
Flushed the gas tank and dug into some wiring issues.
There was an original issue of no spark, but I noticed that Someone had the coil hard wired as well as the WUR. After giving power to the hot side of the coil, I can get the car to run (barely).
I ran it very breifly to get some EGT from the cylinders to see if I have a misfire.
I have temps in the 160 range on the 1-3 bank and no temp on the 4-6 bank.
Jumped cam timing?
lvporschepilot 01-25-2017 11:15 AM
Fuel distributor is jumping out at me. Bad/old varnished fuel gets everywhere, not just the tank.
IMR-Merlin 01-25-2017 02:05 PM
Ok, I'll pull injectors to see what's coming out. but this was on ether..... so I would have expected a little temp on all
prschmn 01-26-2017 04:06 AM
Think I'd be doing a compression/leakdown test before inflicting ether on the poor thing.
IMR-Merlin 01-26-2017 07:12 AM
Thanks for the help gentlemen, after further talk with the owner, it became painfully obvious that the person rebuilding the engine had zero clue what they were doing and a complete tear down will be needed.
I appreciate all the help.
Flat6pac 01-26-2017 10:18 AM
Check the cam timing, that's where a novice would get lost.
Everything else is just torque specs...
Bruce
IMR-Merlin 01-31-2017 08:57 AM
Bruce
You hit the nail right on the head. I showed the owner a video on how to set cam timing and asked if he thought his "mechanic" had this capability and his reply was...
"definitely not"...
poor car.
IMR-Merlin 04-15-2017 08:00 AM
I am bring this thread back up....
Engine is coming out today to check cam timing and do an over all check of things... It doesnt look good.
One question I do have is do they make a replacement plastic connector for the main wire harness coming off of the chassis? The one in the car was in pieces.
Mark Henry 04-15-2017 12:14 PM
Never use ether on a 911 engine, you may as well try to start it by using a sledgehammer on a piston to spin the crank.
IMR-Merlin 04-15-2017 12:17 PM
Beating a dead horse, leakdown is 80-90% on 4-5-6
