2.7RS questions
Hi to all, i may have a lead on a 1976 2.7S Carrera. Included is a new set of Mahle 2.7RS pistons/cylinders.
Was wondering if the stock cams will cope with the 2.7RS pistons and Webers. Should i fit my 2.2S cams? Thanks! |
Is that a USA Carrera, or a Euro Carrera?
-Wayne |
Hi Wayne, serial number is 6460379.
Is that help? Sabin |
Nope, I'm in Maui right now, and don't have access to my serial numbers.
Is it a mag case or aluminum? -Wayne |
6460379 is a 2.7 911S US49 + Canada Coupe 121 Kw (165 Bhp) motor. That will be a mag case.
What injection are you using? |
> What injection are you using.
Plan on fitting Webers with stock CIS pistons, waiting for a set of RS oe JE pistons, more suitable to E-cams and Webers. > That would be a magnesium case. Good or bad thing? 7R? The case hase been case-saved as the seller says. Is there any easy way to check? The engine is out. Thanks! |
I'm sure you will find plenty of comments on the 7R cases in the BBS, do a search. I have a 2.8 litre, 240HP motor with 10.5:1 and MFI, no problem with my 7Rs
Wayne,
If you're in MAUI, what the HE11 are you doing on the board. Get some sun man! :o |
AMEN to that cstreit. If I was there there's no way I'd touch a computer..
I'm sure you don't own your own business either though...
-Wayne |
| All times are GMT -8. The time now is 10:34 AM. |
