Balancing Valves
I might be way way out on the bell curve with this one...
Although intake and exhaust valves aren't being countered by a weight on the other end, the forces of the valves going up and down at a high rate of speed might make a difference. What I found is that all of the exhaust valves are within 0.5g. However, on the intake side, the valves can vary by as much as 3g. Would it matter, should I even try... which brings me to the question... how would you remove 3g of weight from an intake valve without compromising the integrity? Anyone ever wrestled with this one? |
I imagine racers probably do it all the time. |
That is a very interesting observation JB, I have to admit something like that had never crossed my mind. I guess I have always believed that lightening the valves is one of those unchangeable variables. Goes to show you, how creative you have to be for lighter = faster.
I don't think I'd try getting 3 grams off a Porsche valve-but there's always Titanium!
Light valves are good!
Change out the valves and use valves with 8 mm stems like the 993. I don't think an imbalance between the vales matter much. There is a huge difference between intake and exhaust valves... |
Good point on the delta between the intake and exhaust valve weights. And since the spring pressures and install lengths don't vary, I guess they are treated as individual bodies in motion. Hmm... I guess I'll have to find something else in the stock valve train to improve on. However, the inertia of a heavy valve would have it traveling with more force and hammering away on the guide.
But yeah, lighter valves would certainly be better. |
But the best way is ta change valves. Then you can not only get lighter valves, you can get some with a "flatter" backside that will improve performance of the head. |
Lighter is better when it comes to valves, but I've never heard of balancing them. I wonder if it matters as much since they're not reciprocating.
Valves are not a rotating medium so balancing is unnecessary. Lightening valves is done to reduce the effects of inertia.
I've seen titanium valves are around $65 each. In a GT3 four valve motor, that gets expensive fast. I suspect since the two valve 911 engines have larger valves, the material cost makes them even a bit more expensive?
I believe you also need to replace your valve guides with a different material to complement the titanium valves? |
Guides aren't a problem but seats are. You need to use Cu Br-but beryllium
is banned-there are replacement alloys though |
Thanks for the correction Mark
| All times are GMT -8. The time now is 07:23 AM. |
