-   -   Where did I pull this wire from? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/944313-where-did-i-pull-wire.html)
bobswei 01-30-2017 07:58 PM
I posted this on the tech forum with no luck. I'm rebuilding my '72 2.4T and I'm at the point that I'm finishing up last details. But, I can't recall where I got this from? I'm sure it's in the coil/dizzy area, I think. It's around 12" long. There is a similar wire that grounds to the chain box housing, already there. From where to where?
http://forums.pelicanparts.com/uploa...1485834876.jpg
Here's the wire on a '70 E that I used to have. Any ideas?
JFairman 01-30-2017 08:41 PM
My '87 has one like that and it grounds the aluminum rear relay panel that is mounted in rubber mounts. It goes from a 6mm factory ground stud nearby the CDI box to the relay panel.
bobswei 01-31-2017 07:17 PM
Yea, JFairman. I think your right. Someone on the tech forum also mentioned that and it seems like there was a braided wire there. That's where I will install it.
Thanks!!
JFairman 01-31-2017 07:35 PM
Cool. I think one end of it goes under one of the screws that holds the CD box to the relay panel.
