993 Piston Squirters - Superseded Part #
So I have decided to replace the piston splash valves on my 993 engine before the final assembly. I have the part number for the 993 turbo squirters that is 993.101.018.51. Looks like these have been superseded to 993.101.018.53. Are they the same exact part? I am running a 930 turbo pump so I will have sufficient oil flow for the larger units.
I have found both. The .53 version is 3 times more expensive then the .51 version. Can anyone verify these as being the same one. Thanks.
Old 10-11-2017, 09:23 AM
Bump .... Anyone know if there is a difference between these two? Thanks.
Old 10-12-2017, 09:18 AM
One more bump before i order. Anyone have any insight?
Old 10-14-2017, 05:29 PM
