Member 911 Anonymous
Assembly Complete!
Thanks Fellas :-)
Update: Gear Box mated to Engine, Installing this Friday Afternoon ![]() ...and just in time to return Gilles' Engine Stand and Yoke, Merci Beaucoup! Master KTL, Yours is on it way too, I have not forgotten sir ![]() Next, Install, Easy Peasy, this is only my 7th time
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Oh Yeah, no left over Bolts and/or Nuts
![]() ![]() Sandwich Baggies and Sharpie is your best friend Also taking the time to leave bolts where they belong, yeah extra time but Heck, they all went in the correct places, WOoHoO
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-08-2017 at 08:38 AM.. Reason: Posted at 3:00 in the A.M. |
Very cool. Can't wait to see and hear the start-up video. Looks very nice.
'71 914-6 #0372 '17 Macan GTS |
Schleprock
Rock on. Startup and break-in will be a piece of cake.
Kevin L '86 Carrera "Larry" |
Chain fence eating turbo
Congrats! BTDT, doing it again though currently....
Dial 911
Great!..Good on ya mate!!. Like "let the good times roll" eh !
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
Break in #1-2
Filled with 30 Weight Rotella Hand Cranked and Starter Cranked, ALL GOOD Too late to start in my Darn HOA :-( Will start and 20 minute at 2000 RPMs, Dump Oil, change filter and prepare for break in drive for 50 Miles. I think I earned this
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-08-2017 at 08:58 PM.. |
You definitely earned that brew. Job well done.
Mark Jung Bend, OR MFI Werks.com |
20 Minute Break in & 50 Miles Break In SUCCESS!!!!!!!!!!!!!
20 Minute Break In.
SUCCESS! I goofed, forgot to set up zip tie on throttle to keep her at 2000 RPMs that is why video split and I can not figure out how to merge the three videos but I think you can see what I was doing. The last video is te last 2 minutes, NO LEAKS, NO CRAZY NOISES, only Valve Noise but that was on purpose, left them a bit loose just in case pistons want to smack them ![]() DRUCK right on target Temp raised properly Absolutely NO SMOKING, was kinda surprised about this, was expecting allot more ![]() Little to no shavings on magnets ( on 2 oil changes ) I did notice sparkly stuff in the dirty oil but I assume it was the rings bedding into the cylinder walls as planned. 2nd oil change was less after my 50 miles Break In Drive. Accell and Decel hard upto redline, no lugging and nothing under 2000 RPM's. People hated me on the freeway, 30MPH to 90MPH ![]() 25 Miles to SW CHIP to pick up 3.4L Chip THANKS STEVE WONG!![]() SWChips.com - Products SMOOOOOOTTTHHHHHHHH Idle
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-10-2017 at 01:11 AM.. |
Congratulations -- I've been following with great interest, as no doubt have many other lurkers. Job well done. I'm having a beer in your honour!
Sent from my iPhone using Tapatalk |
UnRegistered User
Very nice!
Was wondering how the startup went. Always a "Big Pucker" moment when you spin a fresh overhaul for the first time.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Excellent work. Sounds sweet. Congratulations - you deserve another beer.
Oh Thank You Fellas,
All the credit goes to you all you for your continued contribution, moral support and guidance. I could not have done it without this great brotherhood of exceptional gentlemen. Again, my humble gratitue to you all! ![]() ![]()
Congrats, now go to Willow Springs and turn an leisurely 1:32 on big Willow to break it all in.
I wish but I don't want to break anything prematurely
Post 50 Mile Check, YOU MUST CHECK ALL THE NUTS:
All went well until I check the torque on the fasteners. Specifically #6 bottom left corner Head Stud ( Yes, only ONE ) it pulled :-(. I tried to torque it but it just spun and started to pull the stud out. NOT GOOD. So I will attempt to extract the stud in situ with red loctite over night using the old OEM barrel nut, assess the damage and if okay will use red loctite to insert the ARP studs by cutting a slot for a screw driver to seat in the stud. I KNOW HALF arse measure but if that does not work I will need to drop and TIME Cert the case. Eh no biggy, will remove cylinder with pistons still in place. I was told by an wise old PELICAN that I can use new 574 to disolve/soften up the old 574 for the cam housing. :-) Going to test that if I strip down the p-side
Under the radar
You can keep the heads on the cam housing and leave the cams in place. No need to remove rockers or remove heads from the cam housing as they can be removed as a unit.
Yeah, I was thinking of using loctite, should have went with my gut
Oh well, good news, more hps ![]() That is the plan to keep them on and get new gasket and piece the p-side seals, oh the joy :-) Wow pulled engine in 2 hours, getting faster every time
Damn, that sucks. Don't hear of that too often on AL cases. What did you torque the heads to? Have you had your torque wrench calibration checked recently?
I think it was the stud I removed. I may have stripped the hole upon removal.
I torqued the to 19 then 38 ft lbs per ARP specs. Yeap, they were calibrated using a stretch gauge on the rod bolts, right on the money.
