964 engine reseal - what to replace?
The area around my nose bearing is leaking and the Intermediate shaft cover is weeping in sympathy so I'm beginning a full case split reseal.
The engine was fully rebuilt 12,000 miles ago so I'm expecting the valve guides, bearings etc to be in good shape. Apart from the obvious gaskets and O-rings what parts are once only use? Piston Rings, bolts? http://forums.pelicanparts.com/uploa...1490076651.jpg |
What's wrong with the rebuild 12,000 miles ago? Why split the case? I would fix the leaks and put it back in the car unless there's other issues.
If like the 3.2 case,
Before you reseal, check the Crank and Case for straightness, checking the case journal seats to make sure they are within spec diameter. I would also check the cylinder to case deck, make sure that is absolutely flat so it will not promote leaks or worse binding Cams. When you re-seal, make sure you use the Green viton o-rings, Brown Oil Pump O-rings, and the Black Brown Flywheel and Nose Seals or simply buy the Wrightwood Racing Package via our host. On that note, when you split the case, look at the o-ring closely at the #8 to see if it got pinched and before you remove the perimeter nuts near the #8 and IMS, check the torque spec with a dependable torque wrench. I like to use a weight and fine tune the wrench if it is adjustable. Break a leg brother! |
The only option left for a long term fix is to open the case and correctly seal the area. |
^^^, Outstanding :-D
4 litres in 2000 kms! ****.
http://forums.pelicanparts.com/uploa...1490139479.jpg |
Heat exchangers successfully removed. Down to the nitty gritty. As per the original question, do I need new rings etc for a simple reseal?
http://forums.pelicanparts.com/uploa...1490384383.jpg
3 exhaust studs to be replaced but otherwise happy that job is over. |
Exhaust studs can be a pain... but good that you got them off.
John McM,
Check your rebuild invoice for a #8 bearing. It is not part of the "main bearing set" that may be listed. If you had a complete rebuild (top and bottom) it should not be leaking like that after 12K miles. When did you notice some signs of leakage? Right away, a short while after rebuild or??? Let us know please. cheers |
http://forums.pelicanparts.com/uploa...1490422983.jpg |
Interestingly, when I ordered a set of genuine bearings for my case here in Brisbane from the local porsche centre, it included the number 8 bearing. I was fully expecting to have to shell out a few hundred extra but got lucky for once . |
"Before you reseal, check the Crank and Case for straightness, checking the case journal seats to make sure they are within spec diameter.
I would also check the cylinder to case deck, make sure that is absolutely flat so it will not promote leaks or worse binding Cams" DRACO; I have been looking for information on how these procedures are done. Is it in the factory manual? |
A straight edge placed over the spigots will tell you if the case bores are true and flat.
| All times are GMT -8. The time now is 08:38 PM. |
