From 91429962993bk2914
If you Start Me Up I'll Never Stop, Never Stop
I may have asked this in the early goings but now it is start up time on the 3.0 now in my 914-6 conversion.
I had Webcam refurb the cams to a 20/21 grind set at 1.9-2.2mm w.1mm lashto address Weber 40's and a recurved stock distributor w/o vacuum advance.
Valve lash is .004 on both I&E / Lift is .485 on Intake and .452 pm Exh / duration on I is .258 degrees and .452 on Exh. /
Maybe too much info but my question now is this: what is the best setup for the innards of the Webers as to jets, venturi's, emulsions tubes, etc for initial start me up? I noted what was in the carbs when I rebuilt them so for comparison, I wonder if anyone out there has experience with a 3.0 SC rebuilt similarlly or close and can give direction on carb set up for the Start Me Up phase so I will Never Stop, never Stop , Never Never Never stop......
Sidebar: I have only seen the Stones twelve times but I am sure they have consumed more fuel (drugs) than all of my Porsche cars combined.. and that is saying something as I have had many over 40+ years of this addiction to fuel....
Old 04-02-2017, 05:09 PM
Hi,
I would run:
36mm venturis
155 mains
180 air
55 idle
F26 emulsion tubes (you can also use F3's, but I'd use 150 mains with those).
Remember, you must finalize jetting on a dyno once everything is all adjusted and running smoothly.
30-32 deg total timing should be OK with your 91 octane fuel.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-02-2017, 06:39 PM
Thanks Steve / MUCH appreciated / I will check out your website and see if I can throw some business big or small your way
cheers Forrest
Last edited by Forrestkhaag; 04-03-2017 at 09:53 AM.. Reason: misspelled misspelled and miss Spell misspelled a word
Old 04-03-2017, 09:52 AM
