-   -   help Piston 911T 1969 orientation ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/952677-help-piston-911t-1969-orientation.html)
Rsjack 04-09-2017 11:06 AM
hi team
please help for my recondition porsche 911T 1969 just question :
The piston has a flat surface. I ask myself the question of meaning. The flat is of the exhaust or intake valve side ? :(
http://pimg.imagesia.com/fichiers/1d...dot8_small.jpg
thx for all
tharbert 04-12-2017 09:11 AM
I have to admit, that picture looks a little...odd. Maybe post a few more?
Here's the thing. Most all the pistons I've seen pictured have a lot more relief for the valves on 80mm pistons, even the low compression 2.0T. You can kind of get the idea in this manual page:
http://forums.pelicanparts.com/uploa...1405577221.jpg
Generally speaking, the area with greater relief goes under the intake. The intake valve is larger and lifts just a smidge more if I read Elgin's chart correctly.
Flat6pac 04-12-2017 09:42 AM
What are the casting numbers inside the piston?
Bruce
