-   -   2.7 total rebuild coming will need some help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/953416-2-7-total-rebuild-coming-will-need-some-help.html)
IMR-Merlin 04-15-2017 01:16 PM
Hi guys.
I posted here a few times, but mostly lurk the 930 forum.
I am helping a buddy with a 2.7 car. He has someone who didn't know jack about the platform rebuild the car. I got it here a while back and did some preliminary digging. The care had no compression on 4-5-6 so I suspected the cam timing was off.
Well we pulled the engine and trans today and there were 5 broken rockers on the (R) side of the engine.
Leak down was about 80-90 on the first cyl we checks so I am assuming all the valves crashed on that bank.
So a top end tear down is coming next weekend.
I will be seeking some advice from this board for sure.
If the valves do crash, what is the chance the pistons are that badly damaged that the bottom end needs a rebuild. I am trying to not split the cases.
Brendon
tharbert 04-16-2017 06:35 AM
The rockers worked as advertised. They are designed to break like that when valve/piston contact is made. That (hopefully) saves other parts of the valve train from damage.
Flat6pac 04-16-2017 01:31 PM
Usually when the piston tags the valve, breaking the rocker it shows up on the face of the piston by the exhaust.
The bottom end usually goes when the valve head breaks off bending the rod, holing the piston and head and blowing shrapnel through the injection and in the case.
Bruce
IMR-Merlin 04-17-2017 08:58 AM
I am getting leakdown in the intake and exhaust side so the valve have to be bent. Tear down is happening late this week or weekend
Brendon
fanaudical 04-17-2017 09:54 PM
I hate to say it, but if somebody who didn't understand the motor did the rebuild, then I'm guessing you'll want to tear into the case anyway just for piece-of-mind.
IMR-Merlin 04-18-2017 06:58 AM
From my understanding, he only did a top end rebuild. The Owner was there a lot and he's not even sure the heads were pulled off. I am treading lightly as this "rebuilder" is my buddy's father inlaw....
I have office work all week, then I am planning some shop time to get into the engine. Once I dig deeper, I will post up the carnage.
yelcab1 04-18-2017 07:14 AM
I would hope the pistons are save-able but plan for the worst. Father in law, eh?
IMR-Merlin 04-18-2017 11:55 AM
yeah, it's a touchy subject. I was going to put an offer in on the car and use the parts to build a light weight car to go side by side with my 930... I am glad I didn't..
Jack Stands 04-19-2017 07:40 PM
Once the heads are off, you might have an idea of the damage, but I'd also think that a complete tear down would be appropriate if in doubt.
If you need specifics, Wayne Dempsey's book on rebuilding 911 engines uses a 2.7 as his example and goes through the steps involved very thoroughly.
IMR-Merlin 04-20-2017 07:28 AM
It's on my book shelf
Catorce 04-30-2017 10:36 PM
What's with the trepidation on splitting the case? If the top end looks like that, you could have:
- bad rod bearings
- bad crank bearings
- scored crank
- oval cylinder spigots
- pulled head studs
Read Dempsey's book and do the whole thing.
IMR-Merlin 05-01-2017 10:18 AM
- bad rod bearings
- scored crank
- pulled head studs
I have the book and we are planing a total rebuild now. he's ordered a yoke so we're on hold for a few days.
IMR-Merlin 05-13-2017 05:14 PM
Got my yoke delivered yesterday and pulled the engine number
Looks like I have a 2.7 out of a 75 Sportomatic car
*6459117*
ChrisBennet 05-14-2017 05:32 AM
- bad rod bearings
- scored crank
- pulled head studs
Splitting the case on anything *but* a 2.7 is a just a bit more money.
A 2.7 case is a different animal and will most likely require resizing - sending it to a west coast machine shop for +$1000 worth of work. I'm not saying you shouldn't split the case, just be aware of what you are in for.
DRACO A5OG 05-14-2017 07:55 AM
Just take careful steps in pulling out the old or damaged head studs, you do not want to take off case material when you remove them. Ask me how I know.
I would let a pro do it and have them clean up the threads or insert CASE Savers if needed.
ChrisBennet 05-14-2017 08:58 AM
*6459117*
Funny, I'm just starting on a 2.7 out of a '77 Sportomatic. The crank is on my bench.
IMR-Merlin 05-14-2017 09:19 AM
thanks for the input guys. I will update as i dig in.
HWgeek 05-14-2017 12:37 PM
Timely post, a certainly buddy of mine ;) is helping me (alot!) with my 2.7L sportomatic rebuild. Thanks ChrisBennet :)
Looking forward to this 2.7 rebuild to see how best to do mine!
IMR-Merlin 05-14-2017 12:48 PM
where in New England are you?
HWgeek 05-18-2017 07:01 AM
Oh too funny! Southern NH too. I wonder if we both know ChrisBennet SmileWavy
PM me and we can see if we have Pfriends in common or have met at a tech session etc.
IMR-Merlin 06-11-2017 11:34 AM
Well boys, the problem was found. The "mechanic" never tightened down the cam sprocket on the right bank, so the nut backed off, the pin popped out and all the valves on that side crashed.
We are leaning toward not splitting the cases. The car has a total of 90k on it and this is a second engine (Porsche warranteed the original).
All the bores look clean with a a good cross hatch pattern and no visible pitting. i will be borrowing bore gauges this week to check for ovaling.
I will be in need of 6 rockers, 3 intake and 3 exhaust valves. What do you think the chances are that the valve guides will be ok after crashing the valves?
Oh and good to meet some of you yesterday.
Brendon
IMR-Merlin 06-11-2017 01:59 PM
Also, just an afterthought. Since this is a *engine, what are the chances it's not a magnesium case?
The casting numbers are 901.101.102.7R
IMR-Merlin 06-11-2017 02:03 PM
blah, disregard my last post... it's a mag case... ugh
ChrisBennet 06-12-2017 05:46 AM
Brendon
There is a spec for measuring allowable wear. You lift the valve off the seat a certain amount and see how far it can wiggle. I don't know if that would apply to this situation. Being the conservative guy I am, I would send the heads to Anchor Atlantic and let him go through them. He will also catch the tired exhaust valve springs that the previous engine builder reused, etc.
He's very reasonable, especially as Porsche things go.
IMR-Merlin 06-12-2017 07:59 AM
Thanks Chris, I will look up his information.
IMR-Merlin 06-12-2017 08:00 AM
also, found out the issue on how the car jumped time!! :eek:
http://forums.pelicanparts.com/uploa...1497279647.jpg
IMR-Merlin 06-12-2017 08:07 AM
And the build thread on my car
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/567389-new-member-930-project-11.html
pictures got dropped, so most are here
https://www.facebook.com/BrendonMcQuaid/media_set?set=a.10203697233409192.1168236990&type= 3
HWgeek 06-21-2017 05:49 AM
OUCH! I guess it wasn't torqued correctly! :(
IMR-Merlin 06-21-2017 07:20 PM
Nope, not at all!! I borrowed the tool to remover the cam sprocket nut on the Left bank today from Dick and Precision.... it was maybe 20 lb/ft, and that is being very generous.....
mikedsilva 06-23-2017 06:32 PM
wow
Flat6pac 06-24-2017 02:01 AM
There is a spacer missing between the idler and the tensioner to fill the gap.
Bruce
