-   -   Porsche 964 engine reseal questions. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/954075-porsche-964-engine-reseal-questions.html)
John McM 06-26-2017 03:45 PM
Originally Posted by mikedsilva (Post 9640511)
As for your head to cylinder mating, I didn't use any sealant in that area.. what I did do, was lap each head to the corresponding cylinder using valve grinding compound to get a perfectly flat surface...
Engine has done a couple thousand kms so far, and no leaks whatsoever.
Thanks for replying to that question. It will come in handy as I progress to that point. Right now I'm just starting the reseal.
John McM 06-26-2017 03:50 PM
And the reseal starts. First up I inserted the new stud with a coating of Loctite 263. I did the same to one of the studs holding the oil pump in. As soon as the Loctite cures I can take the nuts off them. http://forums.pelicanparts.com/uploa...1498517316.jpg
http://forums.pelicanparts.com/uploa...1498517349.jpg
http://forums.pelicanparts.com/uploa...1498517381.jpg
http://forums.pelicanparts.com/uploa...1498517406.jpg
John McM 06-26-2017 03:58 PM
Next up was a lot of cleaning with IPA, then blowing clean air into the galleries.
http://forums.pelicanparts.com/uploa...1498517792.jpg
I then renumbered the bearing areas based on photos I took at the time of disassembly. These match the bearing shell numbers so everything goes back exactly where it came from. I cleaned each bearing shell with White Spirits.
http://forums.pelicanparts.com/uploa...1498517684.jpg
http://forums.pelicanparts.com/uploa...1498517722.jpg
http://forums.pelicanparts.com/uploa...1498517764.jpg
John McM 06-26-2017 04:12 PM
Oil pump, intermediate shaft and chains installed.
John McM 06-28-2017 03:18 AM
Pic http://forums.pelicanparts.com/uploa...1498645101.jpg
John McM 06-28-2017 03:21 AM
Nose bearing seal inserted. Alcohol wipe, then bead of Curi T and pushed the Elring seal home by hand.http://forums.pelicanparts.com/uploa...1498645218.jpg
http://forums.pelicanparts.com/uploa...1498645241.jpg
http://forums.pelicanparts.com/uploa...1498645263.jpg
John McM 06-28-2017 03:24 AM
Crankshaft seal part-installed, assembly grease on bearings and place the crankshaft in. I didn't put it fully in as I need to do the nose bearing sealant at the same time as I start to seal the case. That will be this weekend.http://forums.pelicanparts.com/uploa...1498645435.jpg
http://forums.pelicanparts.com/uploa...1498645459.jpg
http://forums.pelicanparts.com/uploa...1498645476.jpg
John McM 06-28-2017 03:27 AM
Running in oil sourced. Mineral low detergent and high zinc.http://forums.pelicanparts.com/uploa...1498645561.jpg
http://forums.pelicanparts.com/uploa...1498645589.jpg
