-   -   LS2 coil wiring? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/954426-ls2-coil-wiring.html)
djb25 04-24-2017 10:36 AM
LS2 coil wiring?
Anyone out there running LS2 coils?
I'm looking for some info on making the plug wires.
It seems like I could just cut down my existing wires and crimp on some new ends for the coils.
Any other thoughts?
djb25 04-24-2017 03:23 PM
Also looking for any advice on mounting the coils. Right now I'm planning on mounting the coils using the valve cover studs, but that only uses one of the two mounting points. Anyone know if this will be an issue? Maybe too much vibration?
Tippy 04-24-2017 04:18 PM
Any other thoughts?
Have them lying on the shelf.
You can buy the terminals and boots for $25. Just search under those keywords for LS1/LS2, etc.
Just cut existing wires and crimp with coax cable pliers.
sjf911 04-25-2017 08:48 AM
I mounted my lowers to the engine tin and the uppers to the intake manifold (3.2 intake). I cut down the wires and crimped on LT ends.
