Which cam for Weber carbed 3.0 and something else
A friend of mine is building a 3.0 and was wondering which cam would suit his engine. He is going to run the engine with Webers.
EDIT: Sooo, without changing the pistons the 20/21 cam would be maximum without valves hitting pistons? (His last engine which was originally 2.7 was converted into 2.5 short stroke (?? or so he says) blew up. ) He has an extra CIS injection system from that 2.7 (2.5) and I was wondering if it would be suitable for my 2.4T which is now running webers. Whats the going price for complete CIS system nowadays? |
Yes, according to WebCam that is the best cam you can use.. Added benefit is that it also works with CIS. I talked to them if they could do any better than that if I was using Webers and they said "not really" because the pistons are the limitation
Terve Zelander. Send me some direct e-mail (timo.kirkkomaki@sroy.fi) and I will try to help you. I have 3.0L engine with CIS pistons, old Solex cams and Webers.
Where do you live ?? In Helsinki too ?? :D |
| All times are GMT -8. The time now is 02:56 AM. |
