1997 993 3.6L piston squirters -not flush w case rib
I may have a issue with pistons quarters, in that the squirters in cylinders 2,4 ,5 are recessed more than a 1/4" from the rib or in other words they are not flush with the case rib as are the squirters in 1,3 and 6.
The engine is down due to a valve guide dropping ,and had no oil pressure problems over the last five years. The issue is ,I do not like the fact that they are recessed anddo not look correct as per 1,3,6. I don't want to create a problem if there isn't one . Thoughts on this ? |
Correction , 2,3,4 are the ones that are approx 1/4" lower than 1,5,6.
They may be a major p.i.t.a to extract ,if I decide to go with larger replacement squirters. |
| All times are GMT -8. The time now is 11:35 PM. |
