Cylinder baffels options
I am rebuilding a 2.0 out of a 1968L. The car was left out in the cold for 10 years here in the Midwest and as you can surmise the tin did not fair well in that environment. After searching other posts for info I haven't really found and answer, so here is my question: what would be my best options for new tin. Does the updated larger engine baffles fit the smaller 2.0 cylinder spacing? This will be a street driven car only, but will have to live in the heat of traffic. I have use new LN Nickies for the cylinders if that matters. Thanks for the help.
I know early baffles don't fit a 3.0
Supertec has some trick RSR style baffles. |
Baffles..........
The baffles are the same through the 2.0 to 2.7.
Bruce |
I have good used baffles for the 2.0. PM me if interested.
Tom hooked me up with what I needed. Thanks for the help
| All times are GMT -8. The time now is 12:50 AM. |
