Regarding bearings in general. The new idea is bearings that are purposely slightly oval when cold, becoming exactly round when heated. |
That's been done for decades on Detroit iron. Also chamfers on crank holes. A sharp bit works ok, a multi-flute countersink would be better. If you don't feel comfortable doing free-hand a jig can be set up on a drill press to hold the bearing and then you can set exact depth you want bevel with the stop on the drill press.
http://forums.pelicanparts.com/uploa...1499000721.jpg |
m42racer, what do think will happen if you leave a burr in the oil hole?
What do you recommend, a countersink or countersink drill bit? Both have 2 flutes like a standard drill bit. What depth? Perpendicular to hole, or at an angle to the perpendicularity of the hole? |
If you are using a drill bit and a bit that is sharp and new, it will have an included angle of approx 120°, just under. It has two cutting faces as well. So you will create a large major diameter at a lesser angle than a 45° countersink bit will. Some may look at that and feel it is not deep enough and keep on going until the bearing shell is compromised. The lessor of an angle will make doing this work harder as the bit will want to bite into the bearing if you are not careful. This is when the burrs will happen. As for the burrs and rough faces of a drilled countersunk hole, have you not seen how a liquid travels through a hole like this verses one without burrs? |
There are quite a few sharp edge transitions between oil pump and eventual exits. Hand or machine chamfering every one might provide some flow optimization but I doubt it's measurable.
This is more about not deforming the bearing by pressing to hard (most people know to let the bit do the work). And not leaving a raised area on back of shell, causing a high spot to wreck crankshaft. |
| All times are GMT -8. The time now is 11:18 PM. |
