-   -   Carrera 3.0 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/962759-carrera-3-0-a.html)
mikedsilva 07-09-2017 11:51 PM
Carrera 3.0
Bought a Carrera 3.0 Motor to rebuild.. back to stock...
Motor was partially disassembled.. most if not all parts are present.
Just got the heads cleaned to see what I am working with...
But, they are just TOO good.. think I might just stick them in a glass cabinet and look at them :)
http://forums.pelicanparts.com/uploa...1499669311.jpg
http://forums.pelicanparts.com/uploa...1499669322.jpg
http://forums.pelicanparts.com/uploa...1499669332.jpg
http://forums.pelicanparts.com/uploa...1499669341.jpg
Flat6pac 07-10-2017 04:16 AM
Looks like they were cleaned first and polished second.
Good luck with the rest.
Bruce
9elf 07-10-2017 04:17 PM
Amazing that they are the same parts. I am also in Brisbane.
Any chance of a link to where they were done?
mikedsilva 07-10-2017 04:46 PM
hi, I posted on the PFA website too..
Here you go.
Tell Ben I recommended him and he will look after you price wise.
Mike D'Silva
Vapour Blasting Brisbane | Wet Blasting in Brisbane
mepstein 07-10-2017 07:58 PM
We have a vapor blast machine. It sure makes things pretty.
Here's some aluminum motorcycle hubs I cleaned up.http://forums.pelicanparts.com/uploa...1499741805.JPG
mikedsilva 07-24-2017 02:47 AM
hmmm... when ordering replacement seals, bearings etc.. for a Carrera 3.0 motor, what car should I be selecting in the pelican parts menu?
The 77 year model lets me choose standard 911S with, I assume, mag case 2.7... and 78 model year goes straight to sC...
Should I assume all gaskets, seals and o rings I need, are the same as for an SC?
