-   -   What is hot PMO set up for DP 2.7 9.5:1 DC 30 CAMS (http://forums.pelicanparts.com/911-engine-rebuilding-forum/963338-what-hot-pmo-set-up-dp-2-7-9-5-1-dc-30-cams.html)
wndsnd 07-15-2017 09:24 PM
Also intakes at 37.5 exhausts at 35.5
I know I will get recommendations from PHO or Clewett but I was wondering if anyone can give me their specs for a similar engine and your comments on results. Ie. Are PMO 46 too large?
Or what jetting and. Nets are you running on 40'S.
Thanks John.
SoyRacer 07-16-2017 01:50 PM
40s 100%. Either Richard will set you up with proper jetting.
40mm for velocity/response and atomization from tip in to 9-k
46mm are best suited for 3.4 and larger (in my opinion) track use cars.
SCOTITUDE 07-16-2017 09:03 PM
ditto
wndsnd 07-25-2017 01:18 PM
Got it. Thanks.
al lkosmal 07-25-2017 07:42 PM
+1
lvporschepilot 07-26-2017 05:27 AM
Or go with a Triumph setup which sits just between the two at about 43mm
al lkosmal 07-26-2017 07:36 AM
This is true. I've had great results with the Speed Triple units.
regards,
al
