ACL connecting to bearings for 1986 930?
Anyone have experience with connecting rod bearings from ACL? They list P/N 6B2463H as standard size and 6B2463HX as extra clearance +0.0125 mm for extra oil clearance race application.
Thanks David |
Acl
Better longevity and consistent clearance than Glyco.Fred
I will be putting rod bearings back in without splitting the case,. I have heard it may be better to run extra oil clearance because the rod journals are not freshly polished. So in this case the HX series bearing might be better even though this is not a racing engine.
These are great in 700HP Subarus. I'd have used them if I'd known they were available at the time.
Sent from my Nexus 6P using Tapatalk |
| All times are GMT -8. The time now is 03:04 AM. |
