I bent, yea bent, a JE circlip trying to install it without a tool. I had two go flying at warp speed, with one still MIA. None were permanently deformed or sent flying using my home made tool.
Clip tool
[1] resizing the case is a process where a little bit of material is removed from each side of the case and then the crank and intermediate shaft bores are recut. This allow you to use standard bearings instead of oversize bearings which cost 3X what standard bearings cost. |
| All times are GMT -8. The time now is 09:45 PM. |
