3.0 CIS cam grinds, 964 vs. web 20/21
I am rebuilding my 82 911SC, and would like to get my cams reground. I have heard good things about both the 964 grind (from Noah and Wayne), and Web's 20/21 grind (From Super-Jim and others).
Wayne, why do you prefer the 964 profile? Will I have any problems passing California smog with either of these cams? Thanks, Tom |
Tom,
As I think I told you in a PM, I bought some 20/21's for the 'Bomber. The motor goes back in the car next weekend, but I never did install them. As a matter of fact, I sold them, brand new in the box to a fellow in WA. Why? Our local smog nazis increased the standards just days after I ordered the cams. We are now very near California standards. I'm sooo proud I could almost $hit myself with excitement! A pro-wrench I trust, told me the car would likely fail with the 20/21's. He knew of a couple of 3.0's with 964 cams that did. As much as I enjoyed driving a 20/21 equipped car (Superman's), it just isn't worth the hassle to me. |
Tom,
I've been corresponding with both Superman, who has the 21/20 cams and GT911, who has just had his SC cams reground to the 964 profile. The spec sheet shows that the 21/20 cam has more lift than the 964 cam so we could expect the 21/20 to make more power. Accord to Superman he has good power throughout the rev range. GT911 says that with his 964 cams set to factory spec the power kicks in at 3500 rpm ( as opposed to the 21/20 which makes it's power starting at 2200 rpm, per Superman). GT911 had his cams reground by Elgin, who recommended that he retard the cam timing for better low-end grunt. He hasn't done that yet but it will be interesting to know how that timing affects high-rpm power. Cost could be a deciding factor, though. Web cam charges $670 for a regrind to 21/20. Elgin charges $250 for the 964 regrind. Hope this helps. |
Doug, I remember you telling me you put the stock cams back in. Did your wrench say it wouldn't pass at all, or could he tweak it to pass?
I am plannin on using Elgin, as they are local. Elgin has a few 911 cam grinds of their own, I need to call them and find out what is the best I can do and still pass the tailpipe test. Reading the specs on Web's page. Elgin's page and Bruce Anderson's book has me a little confused though. From BA's book, the 964 is a little higher lift and longer duration, and from Web's catalog, the 20/21 has more still: 911sc--I=229° .455" E= 220° .402" 964----I=240° .464" E= 230° .425" 20/21--I=258° .485" E= 246° .452" The elgin listings really don't make sense when compared to these numbers, I don't think Elgin is using the same scale, and without really understanding I am comparing apples to oranges. I just want to make sure the more agressive profiles will pass smog. If I have to lean it out for the test, I am OK with that, as I plan on using John Walker's 3% open loop mode and will need to do that anyway. Any Californians running 964 or 20/21 cams in a SC? Tom |
Tom;
I've done a lot of comparisons of the different cam profiles and here's a few conclusions which I've drawn... ID= Intake Duration IL = Intake Lift ED = Exhaust Duration EL = Exhaust Lift LC = Lobe Center (If stated) OL = Overlap PeakHP = Predicted Peak HP speed PeakTor = Predicted Peak Torque Speed The following have been sorted by actual/predicted torque speed based on a regression analysis that I ran. http://forums.pelicanparts.com/uploads/cams0203a.jpg In general, the peak HP speed (assuming other things like intake design and valve size (not an issue on 911's) are not limiting it) seems to be the engine speed when the intake valve is open 0.00011 seconds. I noticed when using a different analysis. This is as follows for the 3 cams that you listed: SC: 6000 RPM 964: 6000 RPM 20/21: 6500 RPM The other two major variables are lift and lobe-center/overlap. Lift: Since a valve is at full lift for only a portion of the time that it's open (~25%?), this has less of an impact then duration. It is also dependant on how well the ports flow at full lift. If you have an early SC with the 39 mm ports, this may not be an issue, if you have a later SC with the 34 mm ports, it may limit the benefit of the 20/21's extra lift. I have seen very little data on 911 head flows, but BK911 on the 911 Technical BBS did flow a couple of early 911S heads. The same thread has the flow data for a 930 head. Lobe Center/Overlap: As far as I can tell, these are two ways of discribing overlap. As detailed in a lot of places, overlap is great because at higher rev's it allows better filling of the combustion chambers. I suspect that this is why the E camshafts make more torque then the T's (abiet at higher rev's), and the S's more then the E's and the 906's more then all of them -- but at 6200 RPM. CIS systems don't like overlap because of the pulses that it causes in the intake. These mess up the air metering system so that the flow of fuel does not match the flow of air. The result is poor running and a lot of pollution. Pollution sniffers don't like overlap because at low rev's unburned fuel can be sucked into the exhaust. If my memory is correct, Webcam allows you specifiy the lob centers for your cams from 3 choices. If you are concerned about emissions, I'd select the widest lobe angle/least amount of overlap option for your cam. As far as which is best... BTW -- For some reason I can never seem to find Webcam's web site when I'm looking for it. Does anyone know what it is? |
Thanks for the info John. Looking at your chart, it looks like the 20/21 has less overlap than the 964, which is suprising considering it has 18° and 16° longer duration. Must be because the lobe center is different. Your numbers make me lean towards the 964, peak power above redline does nothing for me.
Web's home page is http://www.webcamshafts.com/ Still hoping to hear from someone who has passed CA smog with 964 cams.... Tom |
Tom: if I may make a suggestion...
I'm not sure if that weird 24-year smog rule will apply to your car, or even if it's actually 24 years before an '82 SC becomes smog exempt, but for CA you might want to check. Because if so, your car won't be free from smog rules until 2006.
I would call TRE and ask them if a 20/21-equipped (EDIT: and/or 964) 3.0 will pass smog, but my thoughts are it won't. In the meantime (before 2006?), my suggestion is install a 7.31 R/P in your transmission. I can't be entirely certain, but the ring and pinion swap could be comprable in price to the cams, and secondly (more importantly), you won't have smog to worry about. I'd go that route if smog's an issue. There are other things, too: 1) lower profile tires can speed up a car some. 2) lighten the car 3) lower restriction muffler (not the SSI/HEs and muffler setup - they aren't smog legal - just a muffler), might help a bit. Good luck :) |
Tom, Mikey Z was running 964 cams in his SC before he upgraded to a 3.6.
Hey guys,
I am new to all this. Just bought my first 911 a couple of weeks ago. It is a 78 911 SC 3.0. As all of you, I am interested in boosting up my HP from the 180 stock. I would like to get to 220 - 230 if possible. What are some things I can do and roughly how much would each one be? Does switching to 964 cams do a lot? I appreciate all the help thanks, Miro |
There is some good info here and here. 964 cams should make the power come on a little lower in the RPM range. Tom Edit: to fix link to rennlist |
CIS systems are horrible for power, but the 964 cams seem to be a bit more aggressive, and also allow the car to pass smog. If you're doing a rebuild, then everything should be new, and the car should pass smog no problem. If you are simply swapping cams on a tired engine, you may have smog problems.
I'm not too familiar with the 20/21 cams, but keep in mind that power increases are minimal due to the limitations of the CIS system. -Wayne |
Thanks for the replies,
I am not worried about smog since I am in Florida. So what are some of the most basic upgrades (what should be done first)? And also I have no idea of how much the P&Cs or anything else is? I am getting the transmission rebuilt this week and while it is out, do you recommend changing to 7:31 gear ratio? I read in one of the forums that it speeds the car up. Wayne I am waiting on your book to come out in March. I guess I'll get most of my questions answered there. Thanks again guys, Miro |
The 7:31 is a personal preference - you need to do some calculations on your driving preferences, and also your torque curves before you decide...
-Wayne |
If I was in your shoes, I would go for the exhaust backdate. Most people agree it is the most bang:buck, and it is external to the engine.
Everything else is internal to the engine, and is probably best if done in conjunction with a rebuild, which is why I am doing it. If your engine is in good shape, sell it and swap in a 3.6. Tom |
well i just got my 79 930 3.3 w/ 964 cam smogged and it passed with eases. the allowable emission are 0180 hc ppm mines were 0062. CO % is 1.70 mines were 00.50. Also my car did not have the thermo reactors on.
Tom, which cams did you end up using and why? And if you went with 20/21s, did they pass smog?
The reason was a combination of things, economic (Elgin was about half the price of Web) and that for the smog thing I would rather err on the side of caution. A couple people told me they passed, and Dema at Elgin said it should pass with no problem. I haven't tried yet, as the engine is still not back together. Tom |
Thats exactly what I am intending to do unless someone can convince me the Web cams are that much better. I have to believe Porsche has put some thought and testing into their own cam profiles.
I think the 20/21 cams have a bit more lift and duration than the 964s, but I'm not sure.
Pelicanite Jluetjen once circulated a graph showing a slew of Porsche cam specs, including the 964 and 20/21 cams. Do a "20/21" search or "WebCams," and maybe that graph will come up. |
:p Tom |
Du'oh! :mad:
So what's the advantage of the 20/21 cams?
Question concerning the above graph: if 6500 is the peak RPM with the 20/21 cams and 6000 is the peak with the SC/964 cams, AND hp differences between the cams (realistically), are pretty small (the 20/21 cams develop a bit more from what I understand), is it safe to say the only difference and/or advantage between 20/21 cams and stock SC cams, is a powerband raise and not necessarily a "real" horsepower increase?
I think there are so many variables in answering that question. The extra lift and duration of the 20/21s could be choked off by too small exhaust ports or pipes, intate port size, valve size etc... or it may not. To hard to tell without dynoing on specific engine combos. Its suprising how many times you dyno an engine and the horsepower and torque dosn't do what you expect. Sometimes you gain a tiny bit in a very narrow RPM range and lose alot everywhere else. This can show up as a technical gain in horsepower so it looks good in advertising, but in real world driving doen't feel anywhere near as good. I am NOT saying that is the case with Web cams. They have a pretty awesome reputation. |
i am curious as to how the changing of camshafts affects the CIS system. i have had some experience with fitting different camshafts to vehicles fitted with EFI and found that while some ecu's were smart enough to compensate, others were not able to compensate enough usually resulting in poor idle quality and no real increase if any in drivability.
Also on another camshaft subject i have a 77 carerra 3.0 and i was curious as to the cams in it. i believe it has either 200 or 210 horsepower ( i can never remember, it's not that important except for bragging rights), which is not that far from where the original post wanted to be ( i believe 220-230 hp). just a thought. |
The CIS is *not* "smart", in that it has no ECU, but operates strictly on air flow. It's a mechanical system.
CIS does not work well with (radical) cams that have lots of overlap. The intake reversion pulses, upset the air sensor plate, making the mixture unreliable. |
I just picked up a tidbit from one of my recent race engineering magazines that comes into play with a number of the recent posts. The case in point was the Judd LM V10 engine. Apparently the designer was saying that they picked up HP for the LM engine by reducing the overlap of the cam. Why? Because LM engines run with air restricters which especially come into play at high rev's as the engine is sucking more air. Basically as the restictor chokes off air flow, the pressure in the manifold drops (aka: creating a vacuum) which starts to pull the exhaust gasses back into the cylinder and the intake during overlap -- causing a fairly significant HP loss. So they reduced the overlap, which increased the HP by 10's of HP (I don't have the article nearby).
Whenever anyone brings up "radical" cam grinds, overlap and CIS, the discussion focuses on the poor idle charactoristics resulting from intake reversions and sensor plate fluttering. This is certainly true, especially with those people in states with emissions testing. But the CIS can also interact with the overlap at higher rev's since the CIS sensor plate (as well as the EFI sensor flap and or throttle body) can be a significant intake restriction. As near as I can tell (I haven't tested a CIS engine for this) the CIS engine's are drawing a fairly significant vacuum at WOT -- this seems to be why they generally have "undersized" intake ports ('78 and '79 SC's excluded) Basically - another reason why overlap should be avoided with CIS cars, and other cars which have any sort of intake restriction. |
I've been told if someone swaps late SC heads with early SC heads, 964 or 20/21 cams are a must. Otherwise the low-end's going to be terrible. It's probably the same theory if a person stuck 3.2 heads on their SC motor. |
John,
That is interesting about the overlap, I would have never thought of that. As for the 78 and 79 SC heads. I heard, or read, or dreamed, that Porsche built the 3.0L with 39mm intake ports as the optimum port size. But the exhaust with unequal length primaries and a cat caused a restriction that did not allow for the potential of the 39mm intakes. So they made the later 3.0L with the 34mm intakes to increase velocity to try to create some lower end for a broader power band. IF this is true, don't you think the 78 and 79 cars would respond to 964 or 20/21 cams better than the latter cars as long as they both were running SSI or early exchangers? I haven't seen enough examples to know if this is true or not. Does this fit with your analysis? |
Chuck; I couldn't tell you. Like I said, I haven't spent enough time going through all of the different CIS engine configurations. As long as the CIS remains the dominant constraint on the engine's airflow, I doubt that changes in the porting (within reason) are going to have much of an affect.
I have been thinking a whole lot on why Porsche increased the size of the ports from the T to the S engine. The heads can support 300HP as is in the T version. Only trouble is the RPM might be higher than Porsche thought they could live with. SO to lower the RPM and still get the power they increased the port size. In other words you can't get stuff in faster than the piston is moving and if you want more without increasing the piston speed you need a bigger hole. The only problem with bigger holes is that it hurts the low end torque. As to the CIS, its a bastard of a fuel injection system, not real compliant with real world restraints. Overlap is the magic that makes an extra 20 percent HP in a highly tuned engine. An engine is a Pulsed system. A look at the fourier transform of the input system and exhaust system will show how they interact. By overlaying the waveforms proberly one can increase the fill and exhaust significantly over a small rpm band. Ie the magic of tuned headers and tuned input runners. Only problem with all this is that it only works on a very narrow rpm band, usually the high end. everything else suffers, a lot.
Jack:
I agree overlap is certainly critical for horsepower and that is the CIS downfall. Usually with all else being equal, a cam with narrower lobe centers and more overlap almost, if not always, creates more torque than a cam with wider lobe centers and less overlap. And, often at not as high of RPM as you would expect. We also know that torque x RPM = HP. I don't understand your port theory however. My understanding; small ports are better than large ports (stronger pulses, higher gas speeds, better scavenging, etc...) until the RPM of the engine or the engine size gets to the point where the smaller ports will no longer completely fill the cylinder. Camshafts also are one of the variables. At that point you absolutely need to have bigger ports to create more horsepower. I also suspect that the CIS isn't as restrictive as jluetjen suspects. I think Porsche knows enough not to put too big of ports on an engine that has a intake restriction. Boy I could be wrong though!! I could understand however, Porsche not anticipating the restriction on the exhaust side trying to meet emissions, or not wanting to have to retool for it So I suspect that a 39mm intake 3.0L, with 20/21 cams 9:5 pistons, and SSIs would do better than a 34mm intake 3.0L would. Could be wrong, have been before. |
Its my understanding that the poston velocity determines the max intake port velocity. So if the piston velocity is on the low side, ie it is the limitation, not the port size. If you wish to maintain this lower piston velocity, ie not let the rpm go to say 10,000 rpm, but only 6,500 RPM then the only way to get more in the cylinder is to open up the port. In other words the port velocity at 6,500 rpm is the same for either port, 34mm or 39mm.
I am not absolutely certain of any of this but the one point, ie you can't stuff in air faster than the piston is moving. How this relates to port velocity is not exactly clear to me at this point You have a fixed pressure difference of one atm and an orfice restriction (the valve port) Its clear the bigger hole can flow more volume than a small hole. But what all derermines the rate? Given that the std t head can support 300HP maybe there is no difference but marketing??? Help me out on the head flow theory here. |
Just a followup, regarding the smog issue with 964 camshafts:
Passed CA "enhanced" dyno smog check with flying colors this morning. 15 MPH, HC, max 141, measured 11 25 MPH, HC, max 113, measured 21 15 MPH, CO, max .99%, measured .13% 25 MPH, CO, max .79%, measured .24% 15 MPH, NO, max 1144 PPM, measured 212 25 MPH, NO, max 978 PPM, measured 173 Tom |
Tom, great news.
Cat or not cat, open or closed loop, idle co%, etc? I'm curious as I'm going in for smog in VA. SSI's running open loop at the moment. -Charlie |
For what its worth, one can tune an engine with a high performance cam ie 280 to 290 degrees advertized duration, open loop, so that it will pass even the most stringint smog test, by huge margins. Only trouble is you can't drive it over a mile or two before it burns up. In other words smogging an engine is one thing, but being able to drive the car, with the engine tuned the same way is another. The good thing is that there are very few avid hotrodders, consequently very few cars that emit more than they should. For the rest of us the newer cars have finally gotten to the point that a car that passes smog still has performance. In fact better performance than one could dream of for years gone by. The older Porsches have one FUNDAMENTAL restriction in updating performance AND still meeting smog. Lack of water cooling. Water cooling is required to maintain a constant temperature, which is necessary to obtain optimum performance. Without it one is left to emitting a bit more than necessary. Fortunately the additional emmission is insignificant, due to Porsches small production numbers. The Zelots will not let it drop but for a practical matter you are not doing anything to the atmosphere that represents any threat, at all, no matter what you do to your Porsche. But still I can drive my 66 Porsche, and legally emit 100 s times more than a newer Porsche with a high performance anything.. In fact it may be illegal to modifiy my old POrsche to emit LESS! Only in CA.
If you have a problem car that almost passes, retard the timing. I am not a tech, therefore it is legal for me to speculate what may or may not help a car to pass smog, whatever you do RETARD THE TIMING. Techs are supposed to check the timing, but they NEVER do. I am retired and make nothing for doing anything for anyone. SO when I say retard the timing I am not benefiting in any way, it is just somthing I have heard works and I am blindly repeating it. Hopefully someone can benefit from this info. I am not or never have been an auto tech. or made any money working on autos.An additional note, one SHOULD never go be beyond the mfg reccommendatins on timing. If you do so it may reduce performance as well as smog. |
I used the Freq valve duty cycle to set the mixture, I leaned it out until the duty cycle was ~50%. As soon as it passed, I drove across the parking lot, unplugged the O2 sensor and gave the mixture screw a 1/4 turn rich. Quote:
I would love to buy Tony's CIS to EFI kit, but it wouldn't pass the visual portion fo the CA smog ispection. The fact that a modern EFI with a wideband O2 sensor would run much cleaner is meaningless. Quote:
Tom |
| All times are GMT -8. The time now is 02:26 PM. |
