-   -   996 engine from recycler with high leak down (http://forums.pelicanparts.com/911-engine-rebuilding-forum/965362-996-engine-recycler-high-leak-down.html)
yelcab1 08-04-2017 08:01 AM
I am helping a friend with his 996 which blew the IMS and its engine. He bought a used engine from a breaking yard in SoCal. We did a leak down test on it and one cylinder is at 80% leakdown. I am trying to contact the seller to find the history of the engine.
What is the likelihood of the engine sitting around for a long time having a bad leak down getting better after it has been run in a bit?
bpu699 08-04-2017 08:58 AM
Anything is possible... though that's pretty bad. I wouldn't count on it "getting better" especially if you paid a high price for the motor...
Where is the air going? Take off the valve cover, look at the valves... Get a cheap scope and look into the cylinders.
yelcab1 08-04-2017 09:40 AM
Air is going out the exhaust ...
yelcab1 08-05-2017 05:50 AM
No way to save this one. Rigged up the engine to do compression test and got zero compression on 6. The engine is going back.
Mark Henry 08-07-2017 09:37 AM
That's the problem with a used 996 engine. Before install I'd scope the bores with #5 and 6 getting special attention, remove the sump/filter and inspect, oil analysis, crank push/pull test, 2000- replace the IMS, etc., etc.
Even then it's still a crap shoot.
Flat6pac 08-07-2017 01:50 PM
It's a shame they didn't check it. There is so much more to these watercooled motors than just the IMS.
Bruce
