9 bolt crank in early case?
Does anyone know whether it is possible for a 9 bolt SC crank to fit in an early pre-78 case with additional machine work? Or will it only fit in later cases?
I have an older aluminum case that takes a 6 bolt crank but would prefer to use a later 9 bolt sc crank. |
You're 6 bolt case has a value that exceeds an SC case, just sell or trade it.
A 2.7 crank still gives you 3.0 l just go with it Bruce |
PM sent, depending on what you have we may be able to offer an easy stronger solution.
Kevin |
| All times are GMT -8. The time now is 06:17 PM. |
