-   -   Cam Thrust Plate Bolt Torque on 964 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/966784-cam-thrust-plate-bolt-torque-964-a.html)
drola 08-16-2017 06:22 PM
i have looked and looked and for some reason can not find this one specific torque figure. can someone help me out?
i thought i remembered from long ago is was about 7 lbs or so but i want to make sure
thanks
Dmitry at Pelican Parts 08-17-2017 09:46 AM
Hello - I was not able to find the torque specs for you in our 964 DIY section, but we are not carrying the Bentley Manuals which have all the repair procedures, including torque specs. I've included a link below if you're interested in the 964 version.
Technical Data Without Guesswork by Bentley Publishing, Porsche Carrera 964 1989-1994, Softcover - PelicanParts.com
drola 08-17-2017 11:56 AM
Dmitry, thanks for that but i do have the bentley manual, the porsche workshop manual, adrian's 964 companion, hayes manual, 101 projects etc etc
This specific torque value is not listed in any of them. I thought the rebuild manual said 7 lbs but i can not find that book. It's gotta be here somewhere .......
Flat6pac 08-17-2017 12:57 PM
It shouldn't be any different than earlier engines and it's only a 6 mm bolt, so, tight but not too tight should work.
Bruce
mikedsilva 08-17-2017 01:40 PM
According to PFIXIT dvd... 7.5 ftlb...http://forums.pelicanparts.com/uploa...1503006022.jpg
John McM 08-17-2017 06:21 PM
I used the P fix it torque setting after noting a M6 bolt 8.8 has the same generic rating elsewhere
drola 08-18-2017 04:45 AM
thanks for the suggestions. i torqued it to 7 lbs which should be fine. i used s little blue thread lock just in case
