-   -   Part number needed for RSR rocker shaft seal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/971596-part-number-needed-rsr-rocker-shaft-seal.html)
82 sportsc 09-25-2017 09:12 AM
Guys
Wayne's book reccomends using the RSR version and not the original.
What's the part number for this ?
Frank
bpu699 09-25-2017 11:36 AM
Find one of my prior threads. Some other guy found o rings that work...
$60 for some tiny gaskets seems hard to absorb...
TurboKraft 09-25-2017 12:14 PM
911 099 103 52
bpu699 09-25-2017 12:25 PM
Originally Posted by TurboKraft (Post 9750924)
911 099 103 52
4$ each. Need 24? $96....
That may just be the most overpriced Porsche part in existence....
TurboKraft 09-25-2017 12:48 PM
Designed to help solve a very specific problem: oil leaks between the rocker shafts and the camshaft housings. If $100 keeps your 911 from leaking, that's a helluva bargain.
Especially if your alternative is new rocker shafts or replacing camshaft housings.
bpu699 09-25-2017 12:54 PM
Chris how often do these leak? Is this recommended on all rebuilds?
TurboKraft 09-25-2017 01:02 PM
We do them on every engine we build, figuring it's cheap insurance
Every little bit helps on these engines when oil leaks are the bane of 911 ownership.
82 sportsc 09-25-2017 07:02 PM
Thanks guys...
Also found them for $2.25 each on ECS.
Thanks for comments and info
Frank
Jeff Alton 09-25-2017 09:31 PM
We put them on every build we do as well. Cheap insurance. Did they all need it? Don't know. But we know none of the motors ever leak...
safe 09-26-2017 01:21 AM
How on earth do you fit them, do you chamfer the bores??
I tried but they just sheer off when I tried installing some on my engine.
Jeff Alton 09-26-2017 10:52 PM
Fitted to the groves in the shaft they have always slid right in to the bores. We had some a few years ago that would get a "haircut" when we inserted them but we don't source from that vendor any more. We do install the shaft with a light coat of oil as well.
