Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 Engine Rebuilding Forum
tjonesMN
loctite 574 time to cure
engine: 2001 996 3.4l
I used some Loctite 574 as a flange sealant (aluminum to aluminum) last Thursday. I was curious as to the excess being wet 24 hours later and read and heard this is expected behavior and the product between the metal services that are not exposed to air will cure in 24 hours.
Out of curiosity I applied a bead to 1/4 of my oil pan bottom (surfaces very clean) and bolted it on. 24 hours later I took it off and still wet between the metal surfaces.
So, my test worked about as well as Napolean Dynamite adding the crystals to his time machine.
Tried again last night for a longer test with the oil pan bottom.
I did have a thought. This product was in my garage unopened for six months and would have had several days in storage above the recommended storage temp settings of 46-82F. Not a chem E. Is my product simply tainted from my horrific storage habits? other thoughts?
Old 09-25-2017, 12:33 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Loctite 574 cures in the absence of oxygen. the excess will stay wet practically FOREVER. Don't sweat it; it's doing its job where you can't see it.
Current: 1963 356B T6, 1970 914-6 conversion 2.7, 1973 T, 1975 930 Turbo Targa, 1978 928 Race car, 6.57L, 1983 911SC, 2002 911 Targa, 2007 997TT, 2009 997TT, 2004 40th Anniversary Carrera
Only reproduction 3.6 cases on the planet, coming soon www.taorminaracingdesigns.com
Old 09-25-2017, 12:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
I think he is saying it's wet between the flanges. That should be dry. Right? My 574 clogged and dried in the tip after a week.
Old 09-25-2017, 12:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
