-   -   oil cross over line w/ headers ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/973263-oil-cross-over-line-w-headers.html)
ty901 10-08-2017 04:46 PM
all;
decided to go w/ headers & am just now discovering that the stock oil crossover line doesn't like the idea. can someone point me in the right direction re: a solution.
I'm keeping the headers.
engine is a 2.7L
headers are 1 5/8" Cyclone.
TIA
jerry
http://forums.pelicanparts.com/uploa...1507506151.jpg
Flat6pac 10-08-2017 05:28 PM
I just built a 3.0 with a 70/71 911 trans. The under bell didn't work because the clutch cable anchor so owner went to elephant and got a metal, over the top oil scavenge line, like the rubber hose used in the years.
Very nice piece and did what we needed.
Bruce
Trackrash 10-08-2017 06:00 PM
^^ +1
That may be your best solution, depending. My '71 had the oil line, actually a hose, going over the transmission. I used stainless braided aeroquip hose on my car.
The year car you are using and the oil tank configuration, may be a consideration on what type of oil line you choose to use.
ty901 10-08-2017 08:13 PM
@ Bruce; anything, correction, *everything* that Chuck does will be spot on. his list of solutions has expanded quite a bit since the last time I looked.
@ Gordon... you're right. my application is more custom than not. ie; '66 tub w/ bastardized '72 reservoir & twin front coolers.
hose over the trans it is. now to actually make it all happen :D
thanks guys.
BoxsterGT 10-09-2017 07:28 AM
Since you have a custom oil system, I may be able to help.
Here is my Cross-Over hose in M30 similar to the 70-71 911 factory configuration:
http://forums.pelicanparts.com/uploa...1507558208.jpg
This one ends at the Oil Cooler as the factory Cross Under line does.
I can make yours to order. You provide the measurements or I send you one partially assembled and you make the fitment and return it for final crimping. Also available in Yellow Zinc and/or Braided SS hose.
Here is an example of my Hi-Rise Hose set for extra "Fat Tire" clearance:
http://forums.pelicanparts.com/uploa...1507559128.jpg
Priority Mail is reasonable for the extra shipping and the result is exactly to your design.
Len at Autosportengineering dot com
BoxsterGT 11-21-2018 04:59 AM
Bringing to the Top as have had questions on this....
Len.Cummings at verizon.net
