-   -   10.5:1CR too much for single plug 3.2SS? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/973426-10-5-1cr-too-much-single-plug-3-2ss.html)
Nux 08-18-2018 07:37 AM
Originally Posted by mikedsilva (Post 10147280)
Nux, what did you end up doing?
I am about to order some CP 10.5 pistons for my 3.0 Carrera motor. It is using 40mm itbs, efi and race header exhaust.
Or should I only get the 9.5:1?
The cam I am looking to use is the Webcam 464/465.. second from the top
https://i.imgur.com/JGBJvqL.png
I ended up just re-using the Max Moritz pistons. I measured my CR to 9.3. I'm running 43mm ITB, single plug with DC20 Cams. This engine pulls quite hard above 3500rpm.
I have a friend who's racing a single plug 3.0 with EFI on an SC plenum, 10.5cr Wössner pistons and 993SS cams. No issues so far. 245isch hp. I think the old SC plenum is what keeps his engine together. Not sure this combo would work with ITB's.
