-   -   Where are you pulling weight from on the big end?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/974277-where-you-pulling-weight-big-end.html)
Tippy 10-18-2017 06:46 AM
Bo, I paid $200 just to rebush and resize big end at a local machine shop. No balancing factored in. :(
Wished I'd have known about CE the 1st go 'round with my rods.
boosted79 10-18-2017 07:19 AM
"Is that your rig? Home built?"
Yes and yes. It works well. The trick is use long chains to support both ends to get repeatability. I did mine to .1 g, overkill for sure. The spread on the factory balance was 3.7g on the total rod weights but 7.2 g on the small ends.
Tippy 10-18-2017 07:54 AM
That is awesome!!!
Yes, I couldn't get repeatibility the way I was doing it. Locating dowels and the chains alleviate that I see.
When I used to moment-weigh parts, I had dedicated fixtures made of thick SS.
