LinkBack | Thread Tools | Rate Thread |
WTB stock trans-to-engine mounting studs for '87 911 w/G50: Part number? Not in PET?
I recently bought a roller '87 911 with the original G50 trans. I found another '87 engine, but it was installed on an early car with a 915 previously, so the four mounting studs that mount the transmission to the engine won't work on a G50.
I scoured the PET engine and transmission sections but could not find these studs anywhere. There are three shorter ones, and one longer one that also goes through the starter motor mounting hole. Wouldn't mind buying a set of used ones if available...please PM me. Thanks! |
long stud: 999-062-225-02 size is M10x142
short studs: 999-062-099-02 size is M10x105 |
Perfect...Thanks man!!!
The 915 long is the same as the G50 short stud.
Bruce |
Thanks bruce...that will save me $5. Gotta love Pelican!
