ARP rod bolt stretch DIMENSION for a 3.2
Can't find my datasheet for my 3.2 for the proper rod bolt stretch.
Rods are hung, ready for bolt stretch. Anyone know? TIA!!!! SmileWavy |
Check this thread
from the thread "As all that I was checking was the required torque to get the .0100 - .0105 stretch" |
Obviously check with ARP and the part number etc. I guess you can torque if you don't have the stretch gauge
Thank you Duane!
That stretch spec is for 10mm bolts. You should have 9mm no?
http://forums.pelicanparts.com/uploa...1510946158.jpg |
That's what I remember. Thank you!!!!!
I went .01025 to split the difference accounting for error.
Quarter of the way between 0.010" hash mark and the hash mark after. |
| All times are GMT -8. The time now is 01:26 AM. |
