-   -   Carerra Pressure Fed Tensioner - Pop Sound (http://forums.pelicanparts.com/911-engine-rebuilding-forum/977959-carerra-pressure-fed-tensioner-pop-sound.html)
Speedy Squirrel 11-18-2017 08:16 AM
I was compressing a tensioner in the bench vice so that I could get the pin in and re-install it. I was squeezing it slowly with no results, and then I heard a POP sound. After that, it was easier to squeeze. I primed it and re-installed, and it seems to be pumped up. I cannot depress it with a screw driver, for instance. Do you think it is OK?
boyt911sc 11-18-2017 10:42 AM
Compressing a hydraulic tensioners.........
Use a large C-clamp or a vise to compress it. Use an oil hand pump to fill it with oil. Keep us posted.
Tony
Edit: Misunderstood your post. Thought you had difficulty compressing it.
Trackrash 11-18-2017 05:04 PM
Only time will tell. If your chains are fairly new they probably won't skip a tooth if your tensioner fails. AHIK.
snbush67 11-18-2017 08:20 PM
Check the ball and cage (nipple) to make sure it is still intact. Compare the tension to a known good tensioner.
It may be that there was something blocking something and you forced it out, if it holds tension, then there is likely no issue.
Trakrat 11-20-2017 07:22 AM
Might have just been some air trapped in it that was squeezed out.
trond 11-20-2017 07:38 AM
trapped air escaping does make popping sounds....
Speedy Squirrel 11-21-2017 07:55 AM
Thanks buddy, Yes, that turned out to be it. I did not know about the little leakdown hole until I found the tensioner thread that I recently posted too.
http://forums.pelicanparts.com/uploa...1511279715.jpg
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
