Question Cams & oil pump for my 3.0
My question is, cams, I want to go with 964 cams since I'm keeping the CIS, but am adding SSIs. I have a pair of 993 cams that appear to have the same profile, same # on the shaft, 964 247, the only difference is where the threaded bolt goes has a 964# while the 993 cams have a 993#: confused:. I've called around asking about this but haven't had any luck getting an answer , hopefully a Pelican head can help me I also still need a 964 oil pump 930 vs 964 oil pump
For a mild 3.0SC rebuild, which is the best one, a 930 or 964 oil pump and why?
Old 02-12-2003, 06:11 PM
