-   -   2.2L vs 2.4L head towers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/980020-2-2l-vs-2-4l-head-towers.html)
hipdoc 12-07-2017 11:42 AM
I am putting together a 2.2L engine. Is the towers for 2.2L heads the same as the towers for 2.4L heads? Can I use 2.4L heads on a 84mm pistons (2.2L) - I'm assuming they're the same size but different crankshaft sizes.
thanks
356RS 12-07-2017 12:02 PM
Yes 2.2 cam towers and 2.4 cam towers are the same as far as fitting your heads. And your 2.4 heads or 2.2 heads will fit the 84mm P&L's.
