heatsensor 964 gearbox
http://forums.pelicanparts.com/uploa...1513778319.jpg
Hi I am searching the partsnr of the female plug thats fits the heatsensor on a gearbox of a 964 carrera 4 Not the rubber cover but the plug itself. Somebody ? |
HI pablo_o2
I take it is for the white plug on the side of the gearbox you need it for, if so that is the Rev light switch, it has 2 bullit connectors just pushed into the 2 holes in the switch, with the rubber boot to cover it. you may want to move the earth strap up onto the starter mounting bolt and the chassis stud above the starter, unless it has been snapped off?? reagrds mike |
Indeed Mike I mean the white switch but it is a male, meaning there fits a connector over it, that snapped when I removed the engine. Now months later the switch is lost...:rolleyes: so obvious
HI pablo_o2
on a 2nd look , it looks like the ends of the wire connectors are still in the switch on the gearbox, if you get some wire cutters and grab the ends they should pull out of the Rev light switch, you can then re-attach them to the end of the wires to plug back into the switch, as there is no other part required reagrds mike |
| All times are GMT -8. The time now is 12:21 PM. |
