Oil pump small nuts... Loctite?
Checked and reassembled my oil pump. The 4 small nuts holding it together didn't seem to have any loctite on there from the factory...
Figured it couldn't hurt...
You guys use the blue? Red? None?
Thanks, and merry Christmas!
Old 12-25-2017, 03:56 PM
loctite
I have never seen Loctite used from the factory.The pump is well secured at 3 points so probably not much movement for load happening.Ciao Fred
Old 12-26-2017, 04:56 AM
Fred, Happy Holidays!
The three nuts that hold the pump to the case have the safety clips...
I am thinking about the 4 tiny nuts that hold the oil pump itself together. The nuts are really odd, with some kind of capture washer that encompasses the nut...
When I took my pump apart, those didn't seem too tight, and didn't seem to have Loctite on there...
May just use red Loctite to be sure they don't come off... its just that the pass through bolts are fairly thin. Don't want to snap one off due to red Loctite if I ever have to take this thing apart again...
Old 12-26-2017, 05:37 AM
If you're worried use the Red Loctite. It can always be nullified with heat.
Current: 1970 914-6 conversion 2.7, 1973 T, 1975 930 Turbo Targa, 1978 928 Race car, 6.57L, 1983 911SC, 1987 928S4 5 speed, 2002 911 Targa, 2007 997TT, 2009 997TT, 2004 40th Anniversary Carrera
Only reproduction 3.6 cases on the planet, coming soon www.taorminaracingdesigns.com
Old 12-26-2017, 08:16 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
I don't think it would be a bad idea to use loctite on those nuts. I used blue loctite on mine.
BTW, a friend of mine had to rebuild his motor after those nuts came loose on his SC motor.....
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-27-2017, 07:49 PM
When they're first put to together with new bolts at the factory I feel confident in them assembled with no loctite, or however they did it.
With older used pumps and bolts I'd feel better with a little loctite on the pump housing bolts. You know they won't come loose.
Old 12-27-2017, 08:23 PM
Trackrash said all you need to know . Use red loctite . The nuts do not seem very tight on original pumps I have disassembled . I use red loctite . I think tightening the nuts too tight will distort the pump . I like 60 in/lbs .
Old 12-28-2017, 07:54 PM
I am Trackrashe's friend that had the nuts loosen on my SC pump. I bought a brand new, later pump. I removed the 4 nuts and red Loctited them!
Andy Brian
Old 01-01-2018, 07:58 AM
Under the radar
Trackrash's Avatar
Andy, lets see a shot of your new motor! It's going to be a rocket.
Gordon
Old 01-01-2018, 04:08 PM
Hey Gordon! Let me get a shot of it today. I am doing the cam timing.
Andy Brian
Old 01-02-2018, 06:09 AM
Hey Bo,
Sorry to infringe on your thread. Tried to private message you back and it states your in box is full and you need to clear out some of your inbox.
Thanks,
Frank
www.perfectpowerinc.com
www.williamknightperformance.com
www.amsperformance.com
Old 01-14-2018, 03:17 PM
