1967 S Cam distributor recurving
Hi,
Following on from a previous post, I am having my Bosch distributor from a 2.4T 1973 recurved to work with 1967 S cams, matched with 90mm cylinders and 10.5:1 high comp pistons, 2.4 crank, ported cylinder heads and a Zenith carb with 34mm venturis, 145 main jets, 60 idle and 185 air jets. I didn't mention in my earlier post that the S cams were from a 1967. Will the distributor part number 0 231 169 008 work ok with these cams and is it it still the case that the recurve should be set at 28 to 30 degrees BTDC@6000 with no vacuum attached. Thanks in advance. Rob. |
It' s my understanding that all the factory S cams up to '73 are the same.
With single plugs and that CR I would not go over 28 degrees maximum advance. I assume you are eliminating the vacuum advance from the distributor. Even so, you will be on the raged edge using pump gas with single plugs. |
yes, you are right
Thanks.
So should I be looking to permanently remove the vacuum advance? I forgot to say, I'm in the UK where there's plenty of hi Octane pump gas available. |
Not sure why you would want or need a vacuum advance.
http://forums.pelicanparts.com/uploa...1514973750.jpg |
Vacuum advance takes advantage of lean mixtures at part throttle (burn is slower), thus more ignition advance to take advantage; also increases fuel mileage.
At WOT = lower vacuum retards timing (thus no advance) from the vacuum mechanism. If working properly, does not affect total mechanical (centrifugal) ignition advance. Sherwood |
| All times are GMT -8. The time now is 06:37 AM. |
