-   -   Oil bypass - quick question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/983581-oil-bypass-quick-question.html)
profblue 01-10-2018 01:48 AM
Guys, my mag case just came back from the machine shop and I am doing final prepping before closing the case. What is the recommendation to hold the new brass plug inside in place? loctite blue? red?
Flat6pac 01-10-2018 07:17 PM
Use red, you’re never going to remove it again.
Bruce
totle 01-11-2018 02:30 PM
Planning on doing the same in my 2.2 case, including installing piston squirters
What oil pump is minimum when doing this mods?
profblue 01-12-2018 05:13 AM
I'm going by Wayne's book and have the 4-rib pump. Mine is a '73 case so it already has the squirters - which I am currently trying to unblock (waiting for my seafoam to arrive).....engine gets all the suggested upgrades - pressure-fed tensioners, turbo covers, RSR sealing rings, updated idler arms, ARP bolts.
