The 993SS grind is also applicable to your engine if you're changing pistons. JeremyD here on Pelican is one who first comes to mind that used this cam in his former 3.4L 9.8:1 compression ratio single-plug build. A number of other guys have used this cam as well.
I believe the key is that the lift & duration specs for this cam appear to warrant pistons with decent size valve reliefs in order to provide ample piston-to-valve clearance. Pretty sure the 993SS cam with original style pistons does not provide enough clearance (typical desired clearance is 2 to 2.5mm exhaust and 1mm intake) and therefore they'd need to have valve pockets machined into them. So if you went with something like Mahle Motorsports, JE or CP Carillo pistons, those already have the reliefs in them you need |
Change one and you will likely have to change others. Just sticking to stock grinds say an S grind yes the cams reshape the torque curve, an S cam moves the torque peak to the right compared to an E grind or T grind, all else being equal but an S grind in a 2.7 won't behave exactly the same way in a 3.2, the same cam in a bigger motor moves the torque curve back to the left, again all else being equal. The problem w/ using an S cam in a 3.2 is the reversion pulses in the intake due to the the overlap period when both Intake and exhaust valves are both open, This overlap period is great fro making torque at higher rpm but w/ a single pt throttle body doesn't work well at idle and just off idle. The solution is to also use ITBs w/ the S cams. Of course now you are probably reving the motor higher and need further oiling and bottom end and piston changes to accomodate the high lift and overlap and higher rpm operation, perhaps extra cooling as well, Here are some stock torque curves, the more sporting ones will have the torque hump to the right, the less sporting more commuterish will have torque humps to the left. Look particularly at the blue(3.8,993RSvram) and silver(3.6 993nvram) curves, Here both motors have the same RS hydraulic cams, Yet the torque curves are very different, the reason is mostly in the intakes and the extra displacement, The 3.8RS is a wonderful street motor, and serves at track days but the 3.6 would be more satisfying for track even though the motor isn't as strong, the shape of the curve is as important as the magnitude. The most satisfying of course is the GT3 http://forums.pelicanparts.com/uploa...1517415701.jpg You can also compare the stock 3.2 to the highly modified 3.4, the 3.2 is a stock US the 3.4 has S cams 98mm 9.8 pistons S cams and ITBs, at the lower end it's no stronger than stock but does make more power up high |
You are absolutely correct. My bad. In my haste trying to explain I got both functions connected by leaving out the RPM function. Engines produce torque. This is the force acting upon the piston and the stroke or distance functions. Horse power is the calculated factor when the engine speed or RPM is introduced into the equation. Engines do more "work" when the speed of the engine increases. Its this change in "work" that is measured in HP. So I believe the OP wanted to know what cam to use to obtain the best engine performance at 5000 RPM. I believe you want the engine to "feel" the strongest around 5000 RPM. This is the peak torque number I think you are after, not the peak HP. I think for the street, this peak torque number should come down some to make the engine more drivable. I would suggest looking at around 3500 - 4000 RPM. This number is more a function of where you set the cam in assembly than anything else. Hopefully you will choose a cam that will have some LSA than will give a torque curve that will not dip to quickly. Your heads and Intake will play a huge part here as well. When we have to run shorter duration cams to help with the torque and response, we do everything to increase the cam velocities but there are limits to this in these engines. This is where a good design of similar lift and duration can out perform other cams. Choose well. |
HP is just torque at rpm
1 lb-ft at 1000rpm is 2hp 1 lb ft at 7000rpm is 13hp You only care about the torque and the rpm where that torque is developed |
When you first start pushing on the pedal, that's the torque. As you approach speeds where you pedal the fastest you can, torque falls off, but you keep accelerating because those smaller and smaller 'torques' are happening more and more frequently in smaller periods of time TOTALLING more work, or in this case, horsepower. |
I agree w/ you in principle but you are still making a simple thing fuzzier than necessary here are the torque & hp curves for 2 motors, one has globally rising torque the other globally falling, the magnitudes are the same but reversed, the hp curve for the globally falling torque curve still rises for most of it's range which is more fun?, ie sporty which is more of a commuter? Work is area under the torque curve ie W = ∫T dt both engines have identical areas under the torque curves ie they both do the same amount of work, it's just that gearing allows the higher rpm torque to be multiplied to a greater extent The reason torque at high rpm is so valuable is that you use gearing to multiply that torque, the higher the rpm the more opportunity for gearing advantage. http://forums.pelicanparts.com/uploa...1517445454.gif |
When talking about engine torque one needs to take into account gearing because torque at the wheels is what pushes the car forward. If instead of reasoning about torque one looks at the problem from an energy standpoint, the gearing discussion is bypassed and everything becomes simpler. The rate at which a car gains kinetic energy (which is directly related to speed) is equal to engine power minus power losses (aero, friction, rolling resistance...). No need to look at gearing here! |
Bill, you're being a pedantic engineer.....:D
But, thanks for the corrections. Even the most nonmechanical of people understand my analogy and a light bulb goes off.... ;) |
All you can measure is torque and speed and time, from that all else is derived, why deal w/ the derived results when the measured tell the full story predictive data is really all that you care about Predictive comparisons like this are solely a function of measured data http://forums.pelicanparts.com/uploa...1517497745.gif |
The analogy, I like to use is this. Imagine three people pushing a car down a drag strip. Can they do it, yes, but it will take a while.
If the car was running on its own the POWER of the motor would get it down the drag strip much more quickly than the three people did. Same amount of work done, but with more power, it is done more quickly. Power is measured by the speed you do work. Sorry, back to cam choices..... |
Do all inertia dynos have load cells or do they infer power/torque by how fast a rotating mass is accelerating? |
inertial - where rollers of a known mass are accelerated by the cars wheels, these can only measure WOT and coastdown parameters load - either hydraulic(usually water) or electric. hydraulic and electric dynos with sophisticated control software can do step-tests, constant-speed pulls, and even part-throttle testing to the point that full vehicle road-load simulations can be conducted right on the dyno. These are the only kind I'll personally use |
But to do any predictive evaluation you need to back out and have the torque Throwing hp #s around can be great fun but if you want actually evaluate something you need torque, rpm, gearing, aero etc. Just looking at the GT3 torque curve gives me goosebumps, It's no wonder that these cars are so desirable http://forums.pelicanparts.com/uploa...1517415701.jpg |
Bill, so the thrust in this graph was measured by an accelerameter in the car? How does that translate to #s thrust?
The Thrust curves are calculated from the torque (dyno) curve. Torque (ft-lbs) is converted for each gear ratio into thrust (lbs). The gear ratio gives you the distance traveled per revolution to cancel the (ft) component. The RPM component is also converted to speed using the gear ratio. Its a relatively simple conversion and exceptionally useful.
Yes, they can be measured using an accelerator. The reverse calculation is used for phone based "dyno' programs. |
For my cars I also have data acquisition to compare fit, that was why after the initial efforts I went to full data integration w/ aero, weight ets all included to come up w/ acceleration predictions, A is easy to gather data for |
| All times are GMT -8. The time now is 09:00 PM. |
