In fifth gear, aero effects become important at high speeds and this explains why net thrust decays more than in first gear. Maximum speed is reached when net thrust becomes zero. |
What did you end up choosing? |
I'm leaning to 964 cams because a few shops say that this is a GREAT starting point for me, and once i am used to how the engine responds... I'll have a better understanding what I want changed by communicating that I am starting with 964 but want to change 'this' or 'that' in the engine characteristics. I've still got a long ways away to get this engine built... just now finally putting in the time and money to get this completed. |
When building an engine you have to consider the whole system. I won't bore you with what that means. But the 964 cam is designed to work with a fuel injection system that needs to meet smog requirements and will work with a single throttle body, meaning mild mannered. An S cam was designed to work with ITBs and is engineered for power. What personality do you want from your motor? What intake will you use? What RPM will you want your motor to produce power? |
I'd like my motor to produce power at all RPMs.... I guess I don't understand your question. I don't want to have to redline the thing to reach its power peak, that's just putting too much stress on the motor. But at the same time, I don't want to lose power with another 2k rpm left in the gear. |
So, how much you can increase your performance beyond a mild 964 cam upgrade, depends on a piston and intake system upgrade. Look at my Garage for my solution to having power and response throughout the RPM range. There is a great section in Bruce Anderson's Porsche 911 Performance Handbook on upping the performance of the 3.2s using stock internals and more. If I missed something on your build, sorry. You have so many responses and questions on different threads, I can't keep up. |
I 2nd Bruce’s books..... TONS of info from his asking the pro’s and he raced for a while and worked with the pro’s like Jerry Woods, Tony Calis, etc...
If nothing else, choose a build and go from there...
OR, drive someone’s car and get their build specs OR, go to your favorite Porsche shop and see what they say... |
Without getting too custom in my engine build, I am going with 3.4 Moritz style P&C setup. (best for single ignition due to the piston design w/ a lower 9.8 compression) It sounds like the 964 cams is the best choice to improve performance at a conservative level then? |
964 cams will probably give you a modest hp bump from the stock earlier cams. If you want to go a little sportier, there are performance grinds intended for use with stock injection. Dougherty, Elgin, and Web should all have some options.
BTW, DRACO A5OG did a similar build a year or so ago. If you can find the thread it may be worth reading through. I searched and can't find it. |
| All times are GMT -8. The time now is 06:28 PM. |
