Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 Engine Rebuilding Forum
3.2L Fuel and Intake System Restoration
Started my 3.2L engine rebuild. Upgrading to a 3.4L with a set of Mahle pistons and cylinders. Keeping the Motronic Injection. I'll be restoring the 3.2L Fuel and Intake System while the engine gets rebuilt. Started with disassembly and a bunch of photo's
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-11-2018, 08:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Decided to rebuild the fuel lines by plating the original fittings and using my friends Cohline hose crimper.
We used Cohline hose
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-11-2018, 08:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
I didn't like the look of the original fuel injection harness. The tan/gray wire wrap always seemed an odd choice.
I bought some black heat shrink tubing and some new Bosch connectors and set about rebuilding the harness.
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-12-2018, 03:54 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Send a message via AIM to brighton911
Super nice work on the hoses. And I like the wiring harness too. I will be needing a few Bosch connectors, can you tell me you sourced them? Thanks
1986 Targa Guards Red
2012 Cayman S
Old 02-12-2018, 04:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
I got the Bosch connectors on Pelican. Bosch part number 1-287-013-003-INT
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-12-2018, 05:04 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
That Guy
Techno Duck's Avatar
For the short hose from the fuel damper to fuel return line; I would purchase either a Porsche hose or one from Griffiths. The hose is pre formed with the bend and you will likely get a kink trying to install it.
I’m sure your doing it already but rebuild the venturi for the brake booster; just a few O-rings inside of it. Also replace the brake booster hose that goes between the engine and tunnel while the engine is out.
I did everything you are a few years ago; also did the same 3.4L build.
Jon - San Diego PCA #516
1988 Granite Green 911 3.4L
2017 Reflex Silver Mk7 GTI
Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1, 1997 E36 M3, 2003 E39 540i
Old 02-12-2018, 05:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Techno Duck- Great advice! I tried the short hose and you're right! It definitely kinks. Luckily, I had anticipated this and had purchased a Griffith line. I'm putting the 3.4 into a 1975 911 and won't be using a brake booster. I'm just going to cap the vacuum lines.
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-12-2018, 06:55 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Decided to shave the tabs and unneeded mounts off the intakes. I'm eliminating the blower by backdating the heat. I'm also relocating the sensor bracket.
Here they are ready for shot peening!
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-14-2018, 03:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
old man neri's Avatar
I just did mine and I cheated. Instead of doing a 90 turn with that hose I did a 270 with the hose instead. It allowed me to keep a bigger radius and not kink. I have yet to really test it out.
Old 02-15-2018, 10:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Degreased washed and sanded the engine shroud in preparation of painting. Here it is getting a final rinse off.
Final cleaning with Prep-Spray
Painted it with Semi-Gloss Black Engine Enamel. Light first and second coats with 10 minute dry times. Medium/wet Third and Forth coats with 10 minute dry times. Looking to match the black powder coat on the backdated heat ducts.
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-17-2018, 08:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Shot Peening is finished! I was looking to replicate the factory finish.
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-18-2018, 07:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Fuel Injectors are back from getting rebuilt.
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-18-2018, 07:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
nene's Avatar
I like it!
Old 02-20-2018, 07:50 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Started putting it back together!
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-20-2018, 10:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
A few more views
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-20-2018, 10:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Here it is with the black shroud.
1974 911 Coupe
1974 IROC Tribute
1975 911S Coupe
Old 02-20-2018, 10:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Chain fence eating turbo
Looks great!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old Yesterday, 05:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
Registered Minimalist
75 911s's Avatar
Nice work! How about a picture of the 75? Still have it's narrowbody? I'm putting a 3.2 in my 75 as well, but with an ITB intake. You made the stock intake look fantastic.
Does it have the stock manual brakes and original calipers? Gotta keep this car light if you want it to stop. :-)
Duane
http://forums.pelicanparts.com/porsche-911-technical-forum/878569-born-75-me-my-new-911s.html
Old Yesterday, 05:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Outstanding post! can you detail the ‘shot peening’ Process - the medium used and any other techniques necessary to achieve this great result.
Thanks!
Old Yesterday, 06:37 AM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Originally Posted by carlsonroad View Post
Hi... sorry to ask this but, can you tell me where I can find those 2 side heater vents you have?
Do you have a part# for each? I was going to backdate my 3.2 with those, but I'm having problems locating them.
1987 Porsche 911 Carrera Coupe
Old Yesterday, 06:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
