Base gasket thickness
After reading Wayne’s book. He recommends using .5 mm base gaskets if you’ve had your heads machined. Is this accurate? Or wil the .25mm gaskets work?
Measure your deck height and then decide.
Ok
| All times are GMT -8. The time now is 12:43 PM. |
