Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 Engine Rebuilding Forum
Slippery Slope Expert
Steam Driver's Avatar
Camshaft Shim Thickness
I discovered something interesting while checking my cam sprocket parallelism, et al, this afternoon. All of the shims that came with/installed/running with this engine are 0.50mm, plus or minus, not 0.25mm as the books state.
Anyone else run into this? Makes it difficult to make adjustments within a 0.25 range.
OOPS! Ignore this post; I found the answer on a previous thread. Should have researched better first.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 02-24-2018, 02:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Shims are indeed all one size. I believe the window is + or - .25mm. No problemo
No physical quantity completely explains its own existence
Old 02-24-2018, 03:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
