Help on 901 gearbox
Im in the process of rebuilding my 901/5speed . Is it ok to replace the first/reverse idler gear alone? My first gear set is OK but the reverse idler is chipped on the reverse gear. I see them listed separately in the classified's. Thanks Mike
gearhead
Yeah, it might make a little noise but should be fine. Let me know if you have any trouble finding one. I’m sure I can come up with one.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks Matt
