-   -   Help: Mahle 84 MM Cylinder Condition (http://forums.pelicanparts.com/911-engine-rebuilding-forum/990634-help-mahle-84-mm-cylinder-condition.html)
grotvik 03-15-2018 07:41 AM
I purchased a set of 6, Mahle 84 ZD 3 cylinders for my 2.4 rebuild. They don't look good to me but I'm not an expert. The pictures below are of the worst cylinder but they are all relatively the same condition. I planned to have them honed/other but I'm concerned they are far past that.
Opinions please.
Thanks,
Greg
http://forums.pelicanparts.com/uploa...1521124842.JPG
Speedy Squirrel 03-15-2018 11:54 AM
Those are the Biral cylinders, with the iron liner and aluminum fins. If those black smudges can be felt with a fingernail, they are pitted from rust, probably too deep to clean up by honing.
grotvik 03-15-2018 12:26 PM
Yes, the smudges can be felt with a fingernail.
BURN-BROS 03-15-2018 12:28 PM
Typically we bore them out 1mm and get pistons made to suit the build.
Tyson Schmidt 03-20-2018 11:14 AM
I second what Burn Bros said.
85mm is the max you can bore the Birals. A set of custom 85mm pistons will run about $1000. Just tell that what cams, and CR you want. CP pistons should still have the needed info from when I had my last set made.
